hey guys this is a bit of an eoi at the moment.. im trying to decide if i should remove what i need from the car then sell the rest complete or if there is enough interest i might just wreck the vehicle
it is a 92 (afaik thats what i was told) r32 gtr not compliable no id tags and a bit rusty complete exterior complete interior complete driveline still a complete running drivable vehicle
i purchased the car because i needed parts for my other car im doing up and it was proving way too difficult to find the parts i needed without going interstage (read : WA) so i just bought a complete car thinking it would also help alot more other people having difficulty finding parts locally..... once i have finished my car and removed what i need the rest will essentially be not needed and only getting in the way
please keep in mind for now this is an eoi.... there are parts i obviously dont need buit to be totally honest im not 100% sure in total what i need untill i start doing my other one
please show interest at this point by reply and pm if you are after something.... hit me up ill either say yeah its available (if i know i wont be needing it) or no if i know i might require the part/s
if you cant accept the fact that the parts you need i might also need and might not be for sale please do not reply
at this stage i wish to keep engine and box setup and most things associated with it like loom ecu cooler bov's piping kit etc etc
i am sorry for any confusion at this stage but im just trying to see if i can start to get some money back for the parts i do not need as it was quite a stretch for me to get it in the first place.... i just cant go selling parts i may need because that would defy the purpose of buying the car for parts all together
located in toowoomba 1 hr west of brissy
cheers John
at this atge unless i sell a passenger seat at the same time i wont seperate
but i have a real good r33 gtr v spec drivers seat and rail if you only wanted 1 seat/// throw me a pm :spank:
Edited by WHITE R32
mate I would be interested in some things you might want to get rid of, just compile a list of what you dont plan on using and we can see from there
ive asked that this thread be closed as i have had waaayyyyy mor einterest and demand for parts than i had imagined...
ill repost it when i have sorted myself out its just becomming way hard for me to work it all out what i can and cannot get rid of untill mine is finished... thanks
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
