Hi all,
I have had my car for over a week now and today have noticed, after cleaning the carbon build up from my bumper that there are small pin sized rust spots all over the car, i am pretty sure it is rust as it is the same color as rust, it is not paint. I can get these rust spots out with polish, but it will be a big job, to polish the whole car, I will get it professionally detailed, machine buffed, etc.. to get rid of them, seems the easiest way, has anyone had a similar problem, or know what causes this?
Also, i have a large rust area where the boot lid has been scratched, what is the best way to stop this from rusting further and cleaning it up?
thanks
Kris
https://www.sau.com.au/forums/topic/24785-small-rust-spots-all-over-car/
are you sure they're rust spots? I mean, to see rust appear, the pin sized scratches would need to have cut through the clear coat, the base coat and the primer. Stone chips at the front of the car will do this, but all over the car? Not likely.
Check the bonnet - if you see any on there, chances are they're not rust as the bonnet is aluminium.
To prevent the rust spreading on the boot lid, you really need to clean the area up, apply an anti-corrosion liquid and have the damage repainted.
thanks, but it honestly has to be rust, i understand what you are saying but after getting second opinoins it appears to be rust spots, i honestly don't know why or how, maybe previous owner was a beach goer and the salt from the beach got to it, not too sure,
i will see if a detailer will get them out for me as for the boot, it is not serious as yet so i will stick to my plan and get my engine mods first
thanks
kris
hi if you live in or near coastal areas. open metal ie chips on your cars body are very sesitive to the salty air from the sea.
jetdat is correct, you have to get it back to bare metal ard prime it immediatly. if a fraction is left over, it will eat away the metal again.
also look for those areas that start to bubling up too.
ron
skyliner33wa
i recently got the same shit on my car!
i just got a front pipe fitted and it had all this metal shavings in it, and i asked the guy who fitted it to blow it out with the air compressor before fitting it, but i think he forgot :(
now i have all these little orange specs on the back of my car, even on the rear BUMPER which is plastic. i think the metal particles must have blown out the exhaust and got stuck to my bumper, then rusted when it rained. pretty pissed off, they dont come off very easily.
Chris.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
