FOR SALE:
Make: 1996 Nissan Skyline R33 GTR V-Spec
Colour: Marron (Cherry Red)
Transmission: 5 Speed Manual
Kilometers: 96xxx
Registration: 1CXN-000
-Engine-
RB26DETT
HKS DD Air Filters
Z32 AFM
Trust Intercooler 150mm "Dual Entery"
Splitfire Coil's and Lead's
R34 GTR N1 Turbo's
Xforce Dump Pipe's
Bee Racing Engine Pipe
Trust Relocated Oil Filter and Blow Off Valves
Trust Oil Cooler
3.5" Cat Back Exhaust System
HKS Dragger Muffler
Hi-Flow Catalytic Converter & Resonator
-Exterior-
Nismo GTR Rear Pods
Clear Side Indicators
20 Grade Window Tinting All Around
Alpha Super Bright LED Park Lights
I-Concept 6000k Xenon White Halogen Bulbs
-Interior-
Nismo 320km Dash & Matching Din Gauges
Apexi Power FC
Apexi AVC-R
Apexi Turbo Timer
Pioneer Head Unit (Mp3/Mp4 & Ipod Ready)
Pioneer 300Watt Amp
Pioneer 12" Subwoofer
Clarion Front & Rear Speakers
Fire Extinguisher
Sparco Steering Wheel & HBK Boss Kit
-Handlering-
R33 V-Spec Suspension with Nismo Lowered Springs
Works XD9s 18/10 Powder Coated In Gloss Black
265/45 Maxxis Tyres
DDS Slotted Rotors
Braided Break Lines
-Fuelling-
Bosch 044 In Tank Fuel Pump
Nismo Adjustable Fuel Regulator
-Driveline-
Exceedy Heavy Duty 5-Puck Single Plate Clutch
Braided Clutch Lines
Nismo Short Shifter Kit
-Security-
Cyclops Blue-Line Alarm System with Shock Sensor add on
*Just serviced by AutoWork Shop, Full Green Line 100k Service
*Dyno Tuned By AllStar Garage (410awhp)
*Also got permits for every modification on the car
*12 months rego
*Motor and Body in A1 Order
$30,000 Ono.
Genuine Buyers only
Please PM me if your intrested.
Yes i will consider swaps plus cash my way, but i would rahter a straight cash deal and i will send this car interstate at buyers expense, PM me if you are interested.
  • 3 weeks later...
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
