Use the search for "ATTESSA":
http://www.skylinesaustralia.com/forums/At...l=attessa+codes
Good hints in there. Best to check the error code and fill the resevoir with fluid - but you have to do that with the car running to get the level right.
There should be a little gauge on the dash above your fuel gauge, this shows torque split via ATTESSA. If you accelerate, this should go up and down depending on the power being pushed down, if this is not happening, ATTESSA is disengaged, and the fuse and link will need to be checked.
B.
on a 32 the torque guage, only activates when required, if your 4wd light is on, then most likely theres a problem. Open the boot, stick your head under there, and find the box on the left hand side under the parcel shelf, it should have a site glass which is flashing out codes over and over, write down the flashes till they cycle through ( theres a pause between each one) then do a search on the codes, theres a few threads on the codes.
dug these codes up from one of my old threads
have a look:
Dug these codes up from an ancient post.
4WD CODES:
LED FLASHES
1. Right front wheel speed sensor or circuit
2. Left front.........
3. Right rear........
4. Left rear.........
5. ABS right front wheel actuator solenoid or circuit
6. ABS left front.......
7. ABS REAR wheel.......
8. ABS actuator motor, motor relay or circuit
9. ABS actuator relay or circuit
10. ETS control unit power supply or circuit
11. Fore aft G sensor 1 or circuit
12. Fore aft G sensr 2 or circuit
13. Fore aft G sensor 1, Fore aft G sensr 2
14. G sensor power supply 1
15. G sensor power supply 2
16. Lateral G sensor or circuit
17. Air bleed connector or circuit
18. ETS pressure switch or circuit
19. ETS motor, motor relay or circuit.
20. ETS solenoid or circuit
21. THROTTLE sensor or circuit
22. ETS oil level switch or circuit
23-
24 or continually ON or OFF: ETS control unit, ground or ciruit.
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
