  • Replies 49
Posted Images
currently i dont want to split gear box and transfer case,
If you do decide to split the box I'm after the plate inside the bell housing that the pivot bolt mounts on. Mine cracked when removing broken pivot bolt thread. PM me
If the C-Pillar trim is in good condition I will take them. Mine are cracked, It was the c-pillar ones I was after but I better double check that the c-pillar trims go around the quarter glass on the inside. Better be safe then sorry.
Wrecking 1989 R32 GTR, has rear right hand damage,
All Parts are located in Logan QLD
all parts available
RB26dett, $3500
GTR gearbox, $800
headlights, $300
Justjap inter cooler, $250
front mount oil cooler,
GTR radiator, $80
Front Bumper Reo, $250
Rear Bumper Reo, $100
Front Bar fiberglass, $180
standard GTR front bar, $300
GTR rear wing, $150
plenty of other parts f/s, please pm me.
Interested in the GTR bonnet can you post some pictures as to what condition it is in and what price would you like for it
thanks
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
