Any opinions on which new(ish) car allows for a high degree of power
increase without opening a money pit of supporting mods ?
It seems the premium cars (lotus, BMW, audi, porsche etc) cost you an
absolute bomb for even the simplest upgrades (exhaust, re-flash, etc)
and because of crammed engine bays and tight electronics integration
it is really something few get into ..
Anything with a DSG or tiptronic or trick gearbox (hmm R35) is going
to have a fairly hard ceiling not too far above stock power output ..
so..
S2000? golf gti? mazda? vette?
Is after-market modification beyond the "flash for an extra 20% torque"
a dying business?
https://www.sau.com.au/forums/topic/248024-which-recent-car-is-highly-tunable/
What kind of price range are we talking here? For something "relatively" cheap, xr6 turbos or anything with a LS2 in it can get quite a decent amount of power output with some small mods. Depends what your after though.
Edited by PM-R33
so..
a dying business?
I have to disagree with you on BMs!
Herbert Gattermeier at Bavariacars Motorsport will according to a reasonable budget,
i) create performance modifications
ii) manufacture Turbocharger conversions on most BMs (except for E36 320i)
iii) add BMW Supercharger kits
That's his & his son's business and it's what they do best!
www.bavariacars.com.au or E-mail [email protected] or contact BMW Owners' Club
xr6 yeah I guess .. just. can't. bring. myself. to that point. In another life,
where I'm a successful tradesman with a thriving cash if possible mate business, maybe.
plus you probably have to spend $8k on a big brake kit even stock.
Any opinions on which new(ish) car allows for a high degree of power increase without opening a money pit of supporting mods ?
Most turbo cars will still let you screw out good power gains without much outlay, once they figure out how to get past the electronic nannies. Most Euro cars (like the Golf GTi you mentioned) are tuned for flat torque delivery rather than outright power, so reflashing the ECU with no hardware changes do see massive power increases and a more "fun" delivery.
For example, a VW Polo GTi has 105kW stock, but reflashing the ECU with an Audi TT map will see you at 147kW with no hardware changes. Pop on an exhaust and filter and you might pick up some more, but after that you might need to look at high flowing / replacing the turbo as I think (but am not sure) that you'll have maxed out the small turbo in the car.
As people have said, it's pretty trivial to make lots of power from an XR6T these days. Even the LS powered engines can get a decent amount of power with just bolt-ons.
S2K I wouldn't bother with. The engine is already pretty high strung. I haven't seen too many mods for the Mazda3 and Mazda6 MPS', but then I haven't really been looking. With a Vette (or any car that shares the same small block), I reckon its just easier to buy a crate motor and be done with it. You can buy a ZR-1 or Z06 engine, and make big power with a warranty.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
