hey guys got a few things for sale from a few gtr's ive had
nismo plenum complete with throttle bodies etc $1800
greddy plenum with single 100mm throttle body $1100
cusco 6 point roll cage with carbon fibre removable side intrusion bars $1500
19x10.5 +12 volk te37 wheels in bronze with bridgestone tyres approx 80% - $5000. not negotiable. not a dollar less.
immaculate condition bar 1 wheel whcih has a slight 15-20mm surface scratch, no gutter rash on any.
SMS 0410 487 487 FOR ANY FURTHER QUESTIONS
WILL POST PICS WEDNESDAY
THANKS
ALL PARTS LOCATED IN LIVERPOOL, SYDNEY
Edited by SRB
heres some pics, sorry they were taken from my fone!! carbon intrusion bars, and full 6pt cusco cage with everything needed to install!!
greddy plenum pics on monday, been realy busy and they at my brothers house
i gotta find the throttle bodies for the plenum, but i have the puley spring accelerator thing, if i cant find them, will sell for 1600
Edited by SRB
hi it wont fit, only r34
pretty sure its steel, no1 makes moly bolt ins i dont think
side intrusion bars are cusco items yes, pure carbon fibre! they retail at 2k alone!
thanks
19s sold.
are there any small parts that come with the nismo plenum other than the tb springy thing?? eg metal piping and hoses etc?
no, u just use the existing standard stuff, and since taking it off i have no idea where ive put them.
needs to go after xmas!!!!!! cage and 2 plenums still 4 sale.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
