crap. $30 well spent. although i don't know about the $5 hot dog that was as soggy as a marathon runners undies. yuk!
there were twice as many cars on show compared to last year and some awsome 7 second runs by a few cars, fastest being a mid 7 by an rx7. the drags are still on and the night is getting cooler with a good wind behind them so this time will surely be beaten. there was one skyline but he didn't get a good start.
the burnout comp was great as well including a very skilled driver in a kingswood (i think) that switched to reverse seamlessly three times when he came to the withces hats at the end of the burnout area. i counted over ten sets of tyres blown, five fires and four breakdowns. great show. i missed victor brays burnout but i did hear it all the way at the end of the parking area at the go karts. oh, and i could smell the rubber from there too.
we didn't get the final numbers for attendance but the commentator said there was 25,000 just after lunch time. don't miss it next year guys.
https://www.sau.com.au/forums/topic/24805-supernats-2003/#findComment-528023
Yeah not a bad day. I arrived at 11am and left at 6:30pm after freezing my nuts off (forgot to take a jumper...)
The Go-To-Whoa was pretty poor. 1/2 the drivers just kept on driving straight past the stopping area without even trying to stop, how pathetic.
The burnout comp I also thought was quite pathetic. Of all the big loud earth shaking v8's sitting over behind the pits we had to put up with 50% of the cars not even able to do a burnout, about 30% able to pull wicked burnouts but died literally 10sec into the session and then the other 20% that could pull monster burnouts but the wind blew awake the smoke before i could even get to smell it (that what burnout comps are for right??).
The show and shine wasn't too bad. Went for abit of a wander over there between the burnout comp and the off-street drags. Noticed 1 skyline (the car from the Burnout comp and off-street drags). He wasn't aware of SAU so I made him aware. Neat car, fmic, pod, 3" exhaust, wheels, abit of paint work on the interior drash trim etc, abit of a sound system, wine red 95 model making 170rwkw.
The Off-street drags look quite promising as they all lined up. None of the crappy parents bombadores or work utes just strong american muscle cars with plenty of grunt. But typical Eastern Creek off-street drags, 5 cars run and then 1 breaks down, 15mins later another 5 cars run and another breaks down 15mins later... and so on. So after 2.5hrs of this and with no jumper and with light drizzle i decided to head home...
So $30 entry, sunburnt face, a life time of goosebumps and 3 dagwood dogs later i guess the day wasn't too bad. Better than watching the footy thats for sure.
I'm not sure what they will do next year coz that drag strip won't exist (but instead across the road at the new venue), so I wonder how that will all go.
https://www.sau.com.au/forums/topic/24805-supernats-2003/#findComment-528479
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
