R32 Gts-t (for Sale Or Swap)
Thinking about selling my R32 GTS-T if the right buyer comes along.
RB20DET
5 Speed Manual
GTR Front Bar & Kit
Immaculate Standard Interior (Best You Will Find)
New Leather Shifter & Handbrake Surround
Momo Race Steering Wheel (Suede & Leather Combination) (6 Months Old)
19 Inch Chrome Starcorp Impul Rims
Tein Coilovers
FMIC
Boost Controller
Brand New Exedy Cushion Button Clutch Kit Fitted (1 Month)
New Fuel Pump (1 Year Old)
Front & Rear Sway Bars
No 4WS
Turbo Timer
Full Alarm & Immobiliser System
First Australian Owner. Owned The Car For 2 Years.
Overall Good Condition, Few Marks Here & There As Expected For A 15 Yr Old Car!
Other Details Of The Car Can Be Found Out By Contacting Me.
Never seen Drift / Track / Drag / Dyno time.
Will sell for the right price or may possibly swap depending on what is offered.
Previously when it had WW's.
  • Replies 41
HEY MATE INTERESTED IN A TRADE AT ALL
HAVE A SIL80 WITH
Car has:
phantom purple respray (dark purple)
full nismo kit icl rear pods
s15 t28 turbo 60 000kms old from s15
s15 brakes with R-Spec pads front and mu secret d1 pads rear
whiteline sway bars (6 months old)
HSD HR coilovers 6 months old
Solid subframe bushes
shimmed diff
rear adjustable camber arms
autometer oil/water temp and oil pressure guages
CD player etc new alpine speakers front and rear
front and rear strut braces (spats)
17inch volk rims front and rear (same as your fronts)
JJR 5 stud conversion
Hybrid front mount intercooler
Greddy oil cooler
turbo timer
boost controller
mines?? chipped ecu
3inch exhaust with flexi fitted on front pipe to stop loosening bolts
Pod filter in covered box for legalities
Cusco catch can
9 puk ceramic clutch (exedy i think)
momo steering wheel
comes with a spare dash (not cracked)
air con full system
plenty of spare random bits
new resonator for middle section of exhaust (bought cat back system and didnt use this)
also has rego till NOV next year.
sure there are things i may have forgotten but yeah that basically it.
car has seen 3 track days.
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
