Anyone Seen One Of Ppg's New R35 Gtr Gearsets?
HMM i got an email form someone in the US who saw the PPG sponsorship on the S13 on drifting .com and asked about them... i found nothing on the website (gave him their number though) i remmeber seeing an email from PPG saying they would be on display in jan.
Edited by URAS
hey trent,
you might be thinking about Animal racing? or animal house racing, something like that? there is a dude in the states who made some, claiming unlimited launches, etc
cya next tuesday :D
PPG Transmission Upgrades for Nissan R35 GT-R
Australian gearbox gurus Pfitzner Performance Gearboxes (PPG) have completed their first Nissan GT-R GR6 gearbox upgrades in the form of a drop in first gear replacement. You can see it pictured about sitting next to a standard GR6 first gear.
You can tell just by looking at this picture the basics of this upgrade, a much wider gear to increase strength. The main cause of gearbox failures occurs on the teeth of the first gears after extreme stress. Initially fractures develop and eventually teeth give way. Once one tooth is gone the rest follow like dominoes.
To follow on from this, PPG plan some gear upgrades for big horsepower cars as well as a 1st through 4th gear upgrade set.
Link: PPG Home Page
Source: Titan Motorsports via NAGTROC
From GTRBlog.com
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
