You'd have to get the other injectors to lean out slightly to compensate for the extra fuel you're putting in. Its probably easiest just to put 10% in your tank whenever ur gonna give the car some business like on cruises.
methanol??? now how do you get hold of that stuff??sounds very serious like drag rail serious ,
i just drive a family skyline which i use to scare the wife with
toluene is very easy to get and is quite good at stopping detonation,im running 27degs advance
tell me more (please)about your install qic33, where did u locate the injector,pressure of fuel system,switched on how??
would an injector directly after the throtle body butterfly cause 1 & 6 to run lean??
Originally posted by 25t
inasnt
i live in a town with 30000 people, elf racing store is but a dream
methanol is obviously better than toluene but paint thinners are easy to come by in this hicksville
how do u inject methanol anyway?
hahaha gotta love those small towns.
i think u inject methanol the same as nos
  • 4 weeks later...
tolunene injection works quite well. There was an article in a very old issue of fast fours and rotories.
You use a cold start injector/solenoid? for injection. toluene likes to burn at a richer mixture than regular fuel so within reason the metering would be pretty easy. No additives are required.
The other one I was looking at was isopropyl injection using the moreys upper cylinder lubricant kit. Cost of the kit is $60 and mounts neatly within 20mins. even comes with a bottle of the stuff. Can get the kit from super cheap or where lpg gas conversions are done.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
