You'd have to get the other injectors to lean out slightly to compensate for the extra fuel you're putting in. Its probably easiest just to put 10% in your tank whenever ur gonna give the car some business like on cruises.
methanol??? now how do you get hold of that stuff??sounds very serious like drag rail serious ,
i just drive a family skyline which i use to scare the wife with
toluene is very easy to get and is quite good at stopping detonation,im running 27degs advance
tell me more (please)about your install qic33, where did u locate the injector,pressure of fuel system,switched on how??
would an injector directly after the throtle body butterfly cause 1 & 6 to run lean??
Originally posted by 25t
inasnt
i live in a town with 30000 people, elf racing store is but a dream
methanol is obviously better than toluene but paint thinners are easy to come by in this hicksville
how do u inject methanol anyway?
hahaha gotta love those small towns.
i think u inject methanol the same as nos
  • 4 weeks later...
tolunene injection works quite well. There was an article in a very old issue of fast fours and rotories.
You use a cold start injector/solenoid? for injection. toluene likes to burn at a richer mixture than regular fuel so within reason the metering would be pretty easy. No additives are required.
The other one I was looking at was isopropyl injection using the moreys upper cylinder lubricant kit. Cost of the kit is $60 and mounts neatly within 20mins. even comes with a bottle of the stuff. Can get the kit from super cheap or where lpg gas conversions are done.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
