Guys,
After some opinions on semi slicks. I am going to start running Sprints at QR/Lakeside next year in a R32 GTST. It will be fairly basic just stripped out to reduce weight and a little extra power over standard.
I will run 16" standard rims but will spend some dollars on semi-slicks. I spoke to the Dunlop guy at QR on the weekend and he said about $400 per tyre. I think it is about the same for Bridgestones. I have seen some Toyos on Ebay for around $260.
So the question is how much difference is there in brands assuming all are semi slicks with same sizes?
I can understand that spending big dollars to gain an extra few percent if trying to run at the front of the field but I think I am a bit off that.
Anybody got any other suggestions?
https://www.sau.com.au/forums/topic/248107-semi-slicks/
  • Replies 42
Guys,
225/50*16 is the control tyre size for the older Saloon cars. They use Kumho V70As now. If you hunt around you may be able to get one of those guys to buy some tyres for you at their discounted price, or get some of their old tyres cheap. Otherwise, try Hornibrook Motorsport the QLD distributor forKumho Motorsport tyres. They may be cheaper anyway due to the higher volume they'd sell compared to other brands.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4306172
here is where u buy bridgestone RE55s in brisbane
http://www.amecautocare.com.au/bridgestonetyres.htm
the dunlops are said to be just a little gripper, i still sue the re55s as there a little cheaper and still a very very good tires and they heat cycle very well so i can still use them on the street........... they only loose grip once they down the canvas which is awesome.......
i recomend re55 is start with then if u wanna go just that little faster later on buy the dunlops for the extra $150 a tire....
just my opion but, other ppl may have different ones
good luck buddy
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4306376
just a note.
I purchased 4x 18" 265x35 Re55s recently from Donnellan's in VIC and had them shipped to Brisbane $77each cheaper than the price quoted by Amec...
Make sure you check a couple of prices before buying semis...
Michael
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4306391
slapper, did you have them buffed? full depth RA1 is only recommended for use as a wet. Hornibrook Motorsport can buff them for you - its not that expensive. They'll go at least a couple of laps longer after buffing and you'll probably get more life out of them too.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307048
Just be careful what Toyo's you get - avoid the RA-1's, I've got these on my GTST and they are shockers on a hot summer's QR track (only get 1 lap out of them before they turn to marshmellow's). Go the RE55s.
TOYO R888 SEMI SLICK is what is advertised. They don't say what compound.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307050
Dunlops are expensive, but I didn't know they were that expensive. I pay that for R888s in 17". My Bridgestone RE55S cost $450 a corner in 17".
The R888s don't grip as well as the Dunlop offerings, but you should be able to get them new from an authorised dealer for $350/corner. They are one of the cheapest semi slicks out there.
I've found the best bang/buck are the Bridgestone RE55S. I'd get Dunlops if I could afford them and am chasing times, though.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307079
Yeah I don't think there's much doubt that the Dunlop 03G is the fastest tyre at the moment. Be backed to backed them last year with the Kuhmos and they were nearly exactly a second a kay quicker.
I need new rubber for my 32 gts-t and I'm getting O3G's.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307091
I was looking at putting R88s on my GT-R and ended up going with R1Rs - haven't got them on yet so I can't give you a definitive answer about their performance.
When I was researching, I spoke to a rep who suggested the R1Rs over the R888s, firstly because they obviously wear a lot better (think about the percentage of time you'll spend on the street) and also, being a newer design than the 888, has grip levels approaching the 888 without being so reliant on buffing or having good temp in them for max grip. Worth thinking about if you're not planning to be at the pointy end straight away.
I suspect you'll find the 888s on eBay are parallel imports, and GGG compound rather than GG. Naturally Toyo are going to protect their turf, but this PDF does have some valid points.
http://www.toyo.com.au/RacePDFs/Bulletin%2...oxes%20R888.pdf
Edited by Iron Chef
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307195
Are those 888's on ebay from st george tyres?
I used them before, was happy, got quite a few days out of them, but need new tyres asap also
Yeah they were from St George. checked online again today and they are only listing one size now. 225-40-18 $1450 a set.
they also are advertising Falken RT615 in various sizes. they are even cheaper.
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4307551
That's because Falken RT615s aren't an R-Compound tyre. They won't grip anywhere near as well as the R-Comps everyone else is suggesting, nor will they last as long before overheating.
The RT615s are not a proper circuit tyre. In a motorsport setting, I wouldn't consider them for anything other than a wet weather tyre or a hillclimb tyre.
Edited by scathing
https://www.sau.com.au/forums/topic/248107-semi-slicks/#findComment-4309280
    • Seeing as it's an 04 model, I would be hitting up wreckers first.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
