  • Replies 41
For that amount of money you could have had a trust vspl cooler. Nengun sells them for about 80,000yen delivered to your door (about $1070 going on current exchange rate) the only mods you need to do is make a hole for the plenum pipe to come up like yours has. Personally I think the welds look shocking and nowhere as neat as a jap cooler. Sorry, but these are a forum and I am entitled to my opinion :wave:
Rob77, he paid $1800 including piping and labour. I don't think that's too bad. I take it the price you quoted from Nengun was just the cooler? Add in import duty, GST, freight, labour and piping and I'd say it'll be well over $1800. Of course, you can still do better than that too, my setup cost closer to $1500 (600x300x70).
Btw WLD747, there is no way that cooler is 700x400. I measured it on my screen and the ratio of length to height is around 3.2:1. The ratio of a 700x400 cooler is 1.75:1. It's more likely something like 700x220 or 800x250.
the size is prob around 700 x 280 x 70. The price i quoted was just an rough figure wasnt more than $1600 but this upgrade was done within a day. But its usually cheaper if you leave you car there for a week or 2.
Labour is the main factor with intercooler upgrades. Very time consuming job. one more thing this includes a new electric radiator fan not clutch fan to make way for the cooler piping so it removes some weight of the engine pullys.
cheers
ak
planning to run lots of HP, ok it takes a couple of days to put on a cooler and make piping, depends on when the shop is busy. I had the guys working on mine most of the day so they could do it in one day. But i had the intercooler and piping ready.
cheers
ak
Try www.nengun.siteblast.com.au, go to trust and you will see that the intercooler kit is quite reasonably priced. True that price does not include gst, but you may not pay gst on it *wink*. Anyway, the kit is complete and for most people more than enough, cheaper than some aussie kits.
Originally posted by WLD747
twin is good reduces lag from turbo and goes through the cooler at the top and bottom.  So ive heard.
Can you let us know what diameter the intake and outlet pipes are? Unless they've put some thought into it (and it doesn't look like it), this setup is going to do anything but reduce lag.
Also, while swapping to an electrical fan is no bad thing, it didn't have to happen. The route that piping takes definitely doesn't interfere with the clutch fan if its done properly. I've had a very similar layout in my car for sometime.
BTW, what possesed you to get a fake intercooler and GTR badge?
(mutters something demoralising about ricers)
Originally posted by rob77
For that amount of money you could have had a trust vspl cooler. Nengun sells them for about 80,000yen delivered to your door (about $1070 going on current exchange rate) the only mods you need to do is make a hole for the plenum pipe to come up like yours has. Personally I think the welds look shocking and nowhere as neat as a jap cooler. Sorry, but these are a forum and I am entitled to my opinion :D
i agree with the weld comment........not to mention the use of what looks like steel piping...steel rusts therefore throwing crap into the engine.....In regards to twin inlet theres not really an advantage unless its a twin turbo...all your doing with a single turbo there is creating unwanted turbulence in the piping.... Border,nismo,ARC use twin entry on GTR intercoolers...its to stop the turbulence/clashing of compressed air between the 2 turbos
personally I think the price is a bit high as it isn't all stainless piping and the size of the cooler is way to big. and the twin entry says to me these coolers were made for a different application.
the cooler on my sr 32 is 600 x 300 x 76 which is plenty big enough for 500 -600 hp bmt did the cooler piping. personally if you ahve a stock turbo there is no real need for a bigger cooler unless you plan on upgrading you turbo it a bigger one.
I'd say that cooler has been made with a 500-700hp GTR in mind. Its very large and has the twin entry's for the 2 turbos.
Dunno about fitting that to a big HP GTR...........:confused:
:D i thought it was a GTR when i first say the twin intake...
i agree with you troy, and rob77
The welds are average... The pipint isn't stainless and the cooler really is too big.
It'll induce to much lag being of that size.
My cooler is quite a fair size (ARC) and it's single entry, but i'm running a much bigger turbo.
i personally would like to see some bench testing of that twin and a Blitz/ARC/HKS single entry.
That would tell the true story.
Personnaly I believe that running a twin entry cooler will reduce the effectiveness of a single turbo setup, the disturbance of the air flow through the splitter will surely cause restriction to airflow? There is the other point that it may direct more airflow through one entry than the other and cause pulsing??
In my opinion twing entry should only be seen in two things:
a) Twin turbo applications
B) Pornos.
Doc.
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
