Any Alfa Romeo Specialist In Melbourne ?
rs73
 Share
Need a favour...
My brother in law (yes, I know, what was he thinking?) bought an 2001 Alfa Romeo 147 Selespeed with 80,000km on the clock, privately from Sydney without having done all the usual used car buying 'homeworks' properly.
Instead of putting it on a car transport, he and a friend flew to Sydney and drove the car down to Melbourne themselves.
Made it around 500km+ just before Albury when he rang me up telling they're stranded. Apparently the car's transmission had died, possibly from overheating or prolonged highway use. It practically just won't shift to any gear and kept dropping out to Neutral.
Thank's to RACV he and the car got home safely, although got stung by very expensive tow bill. That should teach him a lesson to do his homework next time.
Now he needs to find an Alfa Romeo specialist that could fix the issue he had with the gearbox as he need to have it RWC and rego transferred within 14 days.
Does anyone know any good mechanic in Melbourne area that know Alfa Romeos common problems particularly auto gearbox?
Thank's....
My old man has used Pur-Sang Automobiles for years, they used to be in Coventry St Sth Melbourne but have moved to Fitzroy I believe...
They have moved, and are now called Maranello Motors. They are in Colebrook St Brunswick. They are Alfa experts too, their workshop is always packed with them.
Thank's for all the input, I've fwd them to my bro in law so let him sort it out himself...
I know Alfa is not really the most reliable car out there but what can he do, the egg has been broken, might as well beat it and cook it into an omelet.
Yeah, no wonder it's cheap... $10k, not a little money, but at a few grands cheaper than what others advertising, or willing to part with, there must be a 'catch'...
and I don't think he'd appreciate ylwgtr2's suggestion... as bad as the car goes, he's a student and $10k is a lot for him to loose $9900 in exchange for a $100 wrecker's drive-in price, so he'd be better off spending a few more grands fixing the damn thing
Ewwww selespeed :P
I'll speak to some of the boys at work who do the alfa's and see if they can help you out.. without spending big bucks ;)
I work for Zagame in west melbourne, bad choice on an alfa though, i trust my '89 31 to be more reliable than any new model alfa haha :(
West. He's got the numbers from some of the suggested places above, and might try to ring around tomorrow.
Car may need a tow though, as I just sat in the passenger seat and he drove around the block, the car would only go into 1st, occassionally will go to 2nd, but ocassionally won't shift up and back to Neutral. No Reverse gear at all.
Whirring noise sound like dying gearbox oil pump or something. Not good to try to drive it himself anywhere out of our quiet block.
Still here mate, still in the Skyline world... with a V35 non-turbo now... retiring from the glory of the boosted world...
But just getting a bit busy with my new job, with a lot more variations to do...
selespeed is a known prob with alfas...
ps, where you been, rianto??
Yeah when I was in the passenger seat and looking at it, I wasn't very impressed.
Also the way to switch the selespeed to a full auto mode is not very good, with a button in the middle that seems to stuck,
took him half a minute just to switch it to full auto mode...
Well the good news is he took his car to one in Essendon as it's the closest to home, and they' ran a diagnostic tool on the car,
looks like it wasn't the actuator or the pump as both had given out any error codes.
Sounds like it's the spline shaft or something... should know the verdict by tomorrow...
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
