Item: Power Fc pro Ap engineering for r33 and r32 gtr
Age: unknown! but in good working condition. no faults
Price: $1100
To Fit: r33 and r32 gtr (can be modified for others? check the faq
Comments: Originally i thought i had a d-jetro but turns out it was power fc pro. different features from the normal power fc
The Apexi Power FC Pro Spec has been designed for drag racing use. This unit has additional functions over the standard version.
Ignition cut used for rpm limiter - Regular Apexi Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high powered cars. The Apexi Power FC Pro Spec.CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine.
0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
(does not include hand controller, but i'm trying to track one down they are on yahoo japan for around $150ish shipped)
https://www.sau.com.au/forums/topic/248186-apexi-power-fc-pro-r32-r33-gtr/
The PFC Pro Spec, is it a mafless tune??
Nope, after reading the faq, power fc pro was never made djetro.
this is a discontinued product, power fc pro with the extra features listed above
do you know what firmware version it is?
how can i check???
also like to add i think its got the apexi boost controller too. there is the wiring for it and the solenoid and pressure sensor?
it's listed on the hc, but if you havn't hooked it up, or got the hc i doubt you'd know.
got a pic of the boost kit for it? i'm pretty interested
