I second that.....
Just Found from NissanSyliva.com:
Newbie
Group: Newbie
Gold Member
Group: Gold Sponsor
That will cost you $800 to high flow to 450HP.
Edited by Douse
  • Replies 72
hey guys im currently running a r33 series II with Blitz Cooler LM,turboack exhaust,turbotech boost tee,apexi pod filter.. would i be able to boost up the turbo more higher?like say 14psi or so. or would i need to tune it with a computer..
Yes it will still cost $800 to high flow as its basically using factory housings on a new Turbo core. So you might want to send in a cheap blown one to do the high flow. The ATR turbochargers has no issues to handle 25psi. But factory turbine housing can only hold 20psi.
Edited by hypergear
Bit of a n00b question here...
I have been running a RB25 turbo on my RB20 at just under 1 bar for a while now. So that would be approximately 14psi (I know people are going to say I am not meant to, but I have not had problems so far and there are mixed opinions on this)
Would highflowing it, which would only give me another....say 6psi of boost....really provide THAT much of a power increase? Since the housing is kept the same, and the internals are upgraded, wouldn't this mean the volume of air which can be moved would stay the same? Or is there more to a highflow than I thought...
Once again, excuse the n00bness of the question.....
It will involve honing out the compressor and exhaust housing's to accommodate for larger wheels. Larger wheels means more volume of air is pumped. More air means more power.
Ok, so they are larger wheels, not just stronger ones which can handle more punishment...
The ATR28 450HP profile we made 255rwkws on a CA18det, RB25 should be making towards 270rwkw with excellent turbo response.
these seem to be quite similar to my setup which I have had for a few years. Tuned with all the right mods and its consistantly making 270rw kw and has done so on a number of dynos hub corrected and roller so i'm confident its about this figure. I paid like 1k back then, pushes a good 1.2/3 bar and has done for some time now. I really like the response and I'm sure this would be similar.
First of all we have to use bigger wheels to flow more air. We use aluminium compressor wheels and Inconel steel turbine wheels. All parts in the turbo are specially designed for high boost, and we warranty that for performance applications. So yes they are lot stronger then the stock turbo.
do you guys have a turbo that is say comparable to the HKS GTRS?
looking for the most response possible, and maybe 230-250rwkw
also highly interested in a bolt on solution to twin rb26 turbos, as well as dyno or pics and specs
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
