  • Replies 72
also highly interested in a bolt on solution to twin rb26 turbos, as well as dyno or pics and specs
GTR turbos are easy we can put in ATR28SS 350HP CHAR for twin setup. Those are very very tuff little turbo made to handel high boost. Should get you 400rwkws with excellent turbo response.
very interested, do you have an US dealers ?
Sorry we don't. But we can make them brand new and mail it over if you need. Had many US and Eurp customers lately as our dollar is sitting very low.
Edited by hypergear
I am interested in teting the rb25 bolt on hiflow for you when they are ready.
I can supply you with housings and fit the turbo to my car, tune it and publish the results if you are interested, I have been tuning rb's for a few years and am always interested in bolt on option.
cheers :O
im very interested in this as i am planning on doing it at the same time as a remap,
my car has the usual 'basic' mods (exhaust, intake, fmic, fuel pump, stock boost still)
will somewhere around the 220rwkw+ mark be acheivable with this high flow and a remap in peoples opinions (how much psi would i be looking at runninig out of curiousity to achieve that level)
also what other modifications (if any) would i need to support such power levels.
Edited by AFTDRK
220rwkws is very easy. The high flowed turbo should perform between 230~250rwkws. It should be archived around 18psi or less. By calculation it should archive peek out put of 450HP at 1.3Bar.
There are many dependencies, calculation is normally calculated based on 75~80% of flow capacity. and there are many things that we can do to increase the HP with the ATR28 CHAR in a restrictive environment, but it will results more lag.
The most common profile that we use for R33 high flow is ATR28G2 (400HP) and older G3(450HP) profile. The Current G3 (on the 282rwkws CA) requires a big turbine wheel which the stock housing doesn't seems to have enough meat to be machined out.
Thanks for answering questions etc.
However please be aware you are not a paying trader of this forum, of which there are a lot of businesses paying good money to advertise.
Talking about prices and so on from here must cease until such a time as you are a paying trader.
To become/purchase trader options, please see subscriptions under "my controls"
Thanks.
  • 1 month later...
hey guys, ive sent my turbine housing(not the core) to hypergear today..
ive bein talking to Stao there via email..since i live in perth
anyways..im getting my r33 series turbo high-flowed by them,,
i currently have fmic, pod, hks cat-back exhaust, walbro fuel pump, spitfire coilpack, greddy rs bov, apexi neo afc.
anyways, im just gona bolt this high-flow turbo straight onto my car..
its getting fitted with a ATR28G3 450hp core..
all for $800 :)
anyways my question to u guys is...
will i be able to drive/run my car since i dont have a aftermarket ecu, bigger injectors or a z32 afm..
but ive bein told by hypergear i can..
but 2 workshops here in perth say i wouldnt be able to drive or get my car running...
can some confrim this??
well, they said they can fit a 7psi actuator to it..
so i think im gona get that..
do u guys know what and how much boost i could run with the new turbo?
anyone else running a hypergear turbo on 33 with stock ecu and afm???
I want to see results on a RB20....
If the car's going to be tunned for power I recommend to use 14psi actuator so you can alter boost to 24psi. the 7psi actuator can hold a max of 10psi. So depends on further plans to the car.
Any word on using a ball-bearing core instead of the sleeve bearings you've mentioned earlier - and the extra costing around this? (If you're still allowed to talk about costings in public...)
With BB CHRA it will be a Garrett GT2871R or a GT3071/6R CHRA. To do that it will cost $1200AUD+ depends on the CHRA you want to put in it.
I'm guessing the 2871 would be a more appropriate sizing for 220-250kw and ultimately quicker spooling and response?
It all depends on what you do as calling it "high flow".
What we do is:
Re-profile both factory compressor and turbine housings.
Assemble profiled housings onto ATR28 450HP profile core assemble.
So basically its a brand new turbo with your factory housings for direct bolton purpose.
All ATR turbochargers are covered with 12 month warranty for performance usage.
I have been talking to this guy on NS.com.
So far prooven results with good internals.
gives gt2871r & 3071r garretts a fair run for money! Literally speaking!
For anyone who need rb20 stock turbos for rebuild "cheap as" feel free to contact my at [email protected] or 04218167564.
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
