Hey all,
I am having some problems with 4WD in my R32 GTR, I have searched and read every other post but all other probs seem different to mine.
Basically I am getting no 4WD light on, no error code leds, have checked fluid level etc. etc. I am thinking that my attessa computer is fried (had an alternator power surge few weeks ago) but I was wondering if someone can let me know how to test this before I go and buy another one. It is going to an Auto elec on Thurs and he also hasnt had any experience fixing this so some steps in the right direction would be great!
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/
The AWD light is a warning light, signalling that there is a problem with the ATTESSA system. If you don't get the light on (other than when you initially switch to IGN), then there is nothing wrong with ATTESSA.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4307440
First thing to ascertain- does your 4wd light come on when you turn the key to ignition? If not the bulb is blown. Do you get a gauge reading for the AWD under acceleration?
Thanks for replys :(
No it doesnt, so the bulb must be blown. And no gauge reading, car is definately running 100% RWD...
When my alternator surged it blew lots of other things in the car (including globes in the dash, so its probly blown 4WD one then aswell, also relays, headunit, fuses (since been replaced) etc.), and it is since this time my car is only running RWD. Given my alternator has blown so much stuff up I was thinking it may have done the attessa computer too.
Would there be anything else electrical I should get Auto elec to check and is there a way anyone could point out to test this computer before buying a new one.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4307786
i would have thought that there would be a protecting fuse that blows before the et-s computer would be damaged. Got the wiring chart (in 2 parts ) for the et-s system for what it's worth. Can you try another known working computer?
Picture_clipping_2.zip
Picture_clipping.zip
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308963
Couple more trouble shooting pages that might help you out, don't forget to check the fuse for the attessa pump too.
Picture_clipping_3.zip
Picture_clipping_4.zip
Picture_clipping_5.zip
Picture_clipping_6.zip
Edited by doo doo
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308981
ABS
Just force the brkes to lock up, see if the ABS does its job.
ABS has been taken out.
Yea I dont know how surge got past fuses but almost all of them were blown and it blew headunit etc. which is on a fuse, so im not sure how that happens???
Anyways thanks again for suggestions and thanks doo doo for links, ill check em out now :)
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308991
Hmm pics dont work doo doo, looks like they are in some mac format...
Yeh bugger, they are and they need to be unzipped and downloaded. (know someone with a mac?) They basically do the whole troubleshooting thing so get a download of the manual from somewhere online and check it out- I reckon you'll save yourself a fair bit of grief.
Edited by doo doo
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4309476
Nah dont know anyone with a mac... I do have a R32 workshop manual and have found the pages relating to the attessa system, ill check these and get them to the auto elec to see if he can do anything with em..
Thanks for you help anyways mate!
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4311447
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
