32gtr 4wd Light, Isthere A Workshop/specialist Arround Dandenong Or A Bit Further
Well can't really fix 8 and 9 without putting the abs back in. I normally turn the car off and restart it if it's just 8 and 9, I'd try and ask a specialist about your other error code. I have an intermittent problem as well myself but its a different code, in my case it was a g sensor related issue.
Im sure if you study the wiring diagrams and probe an abs module you could put a resistor in wherever it needs to go and wire it accordingly
when i have a warning light go off in my truck for something
i just get a nice big bit of blue tac and cover the light, after that no worries :D
but im hearing ya is annoying this time of year to get into a workshop
there are workshops everywere, try the little guys they always want work , just need trust
iv been to a couple lil guys and they know nothing about skylines or dont wana touch them,if i watch some one fix the problem once then i could probably do it myself but i wouldnt wana touch something were i dont know nothing about,if some one has some spare time we can try together if not ill just keep ringing arround
Below is a list of ATTESSA Fault Codes, ATTESSA Pro (V-Spec) may differ.
1 Right front wheel speed sensor or circuit
2 Left front wheel speed sensor or circuit
3 Right rear wheel speed sensor or circuit
4 Left front wheel speed sensor or circuit
5 ABS right front wheel actuator solenoid or circuit
6 ABS left front wheel actuator solenoid or circuit
7 ABS rear wheel actuator solenoid or circuit
8 ABS actuator motor, motor relay or circuit
9 ABS actuator relay or circuit
10 ETS control unit power supply or circuit
11 Fore-and-aft G sensor 1 or circuit
12 Fore-and-aft G sensor 1 or circuit
13 Fore-and-aft G sensor 1, fore-and-aft G senstor 2
14 G sensor power supply 1 or circuit
15 G sensor power supply 2 or circuit
16 Lateral G sensor or circuit
17 Air bleed connector or circuit
18 ETS pressure switch or circuit
19 ETS motor, motor relay or circuit
20 ETS solenoid or circuit
21 Throttle sensor or circuit
22 ETS oil level switch or circuit
23 -
24 or ON ETS control unit, ground or circuit
The ABS has been taken out of your car, ignore it. CeJay's removed his ABS as well and also has those codes, but his ATTESSA is working fine. You also had error code no. 2 come up, it has something to do with your 'left front wheel speed sensor or circuit'.
Do some research on this sensor. It's probably stuffed or it's been unplugged by accident.
You don't seem to be having any luck getting this car into a workshop, better off doing the job yourself (Edit: maybe not for some.. do it at your own risk :D ).
Edited by adam-__-
speed sensors are all plugged in i took both front ones out and cleaned them but no luck,got a booking at jap warehouse next wednesday but wouldnt mind something earlier as i had plans for this weekend
so guys looks like ill have to wait till wednesday to take it to japwarehouse unless some1 can find me sum1 to take it to earlier any more places left or we used them all up
Feenin Performance
Dandenong
0403596801
AVR performance
18 beecher st preston
9480 2599
(across the road from impound yard)
Zip Racing
Bayswater
0419290138
Revzone
8-10 molan st
ringwood
98700540
Promax Auto
Alan + Manhon
1 Mary Street
Blackburn
03 9894 0366
Primal Garage
1/380 Somerville Rd
West Footscray
0419156142
Nissco
2 Halbert Rd
Bayswater VIC 3153
(03) 9761 4743
Driftline
21 Thornycroft St, Campbellfield 3061
0425855540
Sabbadin auto
59 roberts ave
Mulgrave
9558 4422
RAJAB RACING DEVELOPMENTS
www.rajabracing.com.au
3/55-57 Randor St, Campbellfield
Vic, 3061
(03) 9357 7587
Poath Road Automotive
151 Poath Road, Murrumbeena 3163
9569 0022
Street Forced Performance
Hampton Park
0425868576
Nismo Performance Centre
Unit 4 / 58 Mahoneys Road
Thomastown
9460 6468
Raceradiators
9793 2798
Racebrakes
9326 6088
Status Tuning
63 Rodeo Drive
Dandenong
97923333 0419590220
RacePace
Holloway Drive
Bayswater Victoria
03 97629421
Dr Drift
Unit 5 / 9 Alick Rd
Brooklyn, Victoria
Australia, 3012
0425 818 755.
Chasers
4/440 dynon rd,
West Melbourne,
9687 7118
RE Customs
16 Yiannis Court
Springvale VIC
03 9548 3414
Sabbadin auto
59 roberts ave
Mulgrave
9558 4422
Protek
273 Dundas St
Preston 3072
9484 3117
