This is Chasers on Dynon Rd, that you mean?
I had my R33 tuned there - PFC, Z32 AFM, HKS2535GT on HKS EZ-II boost controller. Made 230rwkw - only came short due to needing splitfire coil packs and recommended S15 JDM injectors.. which I didn't managed to perform as I decided to sell the car.
If the tuner/dyno guy, Paul, is still there, worth to get him spend some time on your car. He's a good tuner with extensive Motec experience. So if you decided to go to Motec, you definitely can bring your car there for a tuneup! Price is alright, I reckon. About $70/hr 2-3 yrs ago, not sure now.
  • Like 1
I got my car tuned there too... the good thing about Chasers is that they will also work with you to achieve the results you want... e.g. I wanted good mid-range power, good response and an overall daily driver kinda tune - they helped me achieve this and will also give you tips on how to get what you want out of your ride. I highly recommend them. All the guys there are good people.
+1 for Paul and the whole crew there at Chasers. They all race their own cars at the track so they have good extensive knowledge of all aspects of building a car - from a ground-up engine job to suspension overhaul to straight wiring and tuning.
Might have to get in early for next year tho as they're not taking anymore jobs this year.
Oh, and they also just installed a 4wd dyno couple weeks ago so they can now cater for that market too.
good luck mate :P
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
    • $350 for a skid pan is a joke, cost of living is definitely more in NSW 😂
