Hey guys I have for sale 2x 15" Soundstream t4-15 Tarantula subwoofers.
Items have never been used or taken out of the box and are getting in the way so I need them sold.
Looking for around $400 each but can do better if both are purchased. I have no idea what these retail for anymore so I'm sorry if they are expensive.
email/msn = [email protected]
contact phone/sms = 0412717538
Location = Sunshine Coast
I will also take swaps for skyline r33 gear.
Cast Aluminum Basket
Dual 4-Layer, 1-ohm Voice Coils
Cloth Laminated Paper Cone with MD6 coating
Stone Gray Finish with Diamond Cut Edge
Hi Arc, High Excursion Surround
Chrome Plated Back-plate
Low Carbon Top and Pole Piece
Triple Stacked Magnet Structure
Vented and Extended Pole Piece
Black Progressive Roll CONEX Spider
Woven Tinsel Leads
Gold-Plated Binding Posts
BAEISV Hybrid Voice Coil Former
C- Lock Rubber Gasket
Rubber Magnet Cover
Wood Packing Crate with Chrome Appointments
Specs:
Power Handling: 1000 Watts RMS
Voice Coil Diameter: 4.0 Inches
Magnet Weight: 250 Oz
Freq. Response: 20Hz-1kHz
Fs: 34Hz
Qes: 0.449
Qms: 3.722
Qts: 0.401Vas: 12.08 Ft³/58.77 Liters
Xmax: 0.551 Inches
SPL: 91dB
Mounting Hole Size: 14.25 Inches
Woofer Mounting Depth: 8.25 Inches
Recommended Enclosure: Ported/Vented 4.25 CuFt
Port Dimensions: 2 Ports, 3in. dia x 3in
https://www.sau.com.au/forums/topic/248284-15-subs-1000w-rms-each/
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
