hey there,
just need some advice as i am planning on turning the boost up in my car a little
i have got myself a mechanical boost gauge and i was wondering, where in the firewall do i put the vacuum line through, i cant seem to find somewhere obvious to put it through...
sorry for the noob question
Any info would be greatly appreciated :P
Edited by AFTDRK
https://www.sau.com.au/forums/topic/248315-r33-boost-gauge-install/
where are you going to mount the guage? in the dash or pillar pod etc? if in the dash where bouts?
you should be able to find a grommet with wires going thru it in a fair few place.. by mechanical do you mean it needs a boost vac hose to the guage? because im not sure but i think the standard guage runs off a hose? correct me if im wrong people!!
Drivers side of the engine bay to the left if your looking at the brake master cylinder, there is a vacuum hose going to the factory boost sensor & from there wires run through a rubber grommet through the fire wall and come out somewhere above the accelerator pedal. :)
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
