Hey guys I have some parts left from my R34 GTR which I sold a little while ago.
- Nismo coilovers $650
Set of 4 (2xFront and 2xRear) Genuine Nismo coilover suspension, adjustable in height and rebound I think.
They are used but in very good condition and still in their original box.
- Front V-spec diffuser $300
Original Front V-sec diffuser (additional lip) that is used and has scuff marks, good condition
The parts are in Melbourne.
I will post pics shortly.
You can pm me or call me on 0404 235 087
Cheers.
Arnie
Edited by GTstaR
Cheers.
Arnie
hi mate i will call you tomorrow for diffuser thanks , can you put pics up please
bleeds......, thanks for info ashneel
lol no worries man. if you can manage to fit the GTR lip onto you front bar first then the deffuser will fit. but if you dont mind playing around with the lip with a little chop here and there it might fit but will look weired
orh i was asking about the suspension not the lip/diffuser... anyone know?
Hey guys the diffuser is now sold, thanks for all the interest (there was a lot) :P .
The coilovers / shocks are still up for sale. I have had shipping quoted on them to Sydney.
It will cost $64 to get them to a sydeny depot which is in BANKSMEADOW NSW 2019.
It will cost an additional $18 to get them delivered to someones place in suburban sydney.
So if anyone wants them is Sydney I am willing to have them sent to the depot for $700 in total.
Cheers.
  • 1 month later...
The coilovers are still for sale guys.
$600 for pickup in Melb, $650 to a depot in Sydney.
I cant stress how cheap they are now, anyone with an R34 GTR would be crazy to miss an opportunity like this!!!
silly question but does anyyone know if they would fit an r32gtr
if so i want them.........
Im not sure to be honest, best place to ask or do a search in would be one of the tech forums I think.
34 GTR coilovers will fit a 33 GTR no problems. that's a very cheap price for nismo suspension
lower lip aint cheap either.. not surprised someone snapped it up! :banana:
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
