Skyline Oil Pumps....Questions!!
Guest RedLineGTR
OKay i have a r33 gtst i am wondering about the oil pump in them going(failing) at a certain amount of km dont no if it true but someone stated that it was the only downside of the engine itself. With this being true or false dosent really concern me as much.
But what causes oil pumps to stop working or leak enough to destroy the engine. Can i upgrade the oil pump if so what benifits would i get?? Which oil pumps would suit a RB25DET engine.
Thanks Rob
https://www.sau.com.au/forums/topic/24836-skyline-oil-pumpsquestions/
u would never know when the pump is going to pack it but usualy they detiriorate over time although they can just go . keep an eye on your pressure gauge . remember u dont need high pressure to lubricate the engine u need the volume ( its more important than pressure ) and remember the pump has apressure release valve when it reaches a pre set pressure it lets the pessure go so it dont go any higher . on most engines thats about 80 psi but even 30 -40 is enough to keep u r engine healthy as long as the volume is there . i dont know of any upgrades on the oil pumps for rb25s or that the pumps are theit weekness . but remember if the pump stops pumping its only a matter of minutes and the engine is terminaly damaged . ( even 1 minute will stuff up your big ends ) on rb engines number 6 big end will go first . if u race rb26's u need extra baffles in the sump cause as the oil moves around the pick up will run dry and goodbye engine .
What I have heard, and it applies to the majorityof RB engines, is that the heat / cool cycle of the engine causes the bolts holding the oil pump in place to gradually loosen off and oil leaks past the mounting face.
haha
i know this isnt a good explanation
but put it this way
when u do a piss it fows free
imagine pissing a thickshake
not much flow
a lot of pressure
i mean hey its a good enuff explanation
but some pipes in the engine r that small (turbo etc) that a thicker oil isnt going to flow quick enuff and get too hot
sure it protects more but yeah
personally i would use a 10-40 or a 15-40
synth or semi synth
ps dont use helix ultra
made my engine vibrate wickedly and oil pressure was near 0 at idle
and qtr at full rev's
dumped it and all vibration went and oil pressure went back to qtr-4
I just switched to shell helix ultra 5-40 and its great in my r33gtst.
From memory pressure is a tad under 2 when car is at idle (after driving) and goes up to 4 when driving .. more or lss depending on what speed im on ..
Originally posted by RedLineGTR
Okay i noticed that using a higher rating oil Castrol R 10-60w rasied my oil pressure. Is that a good thing or not..would it damage seals if the pressure is too high..or will it damage seals if it is only over filled..
I ran the same oil for 10000km (changed at 5000) and didn't have any problems at all aside for slightly lower power and slightly worse fuel economy. The oil pressure was also higher but it never caused any problems.
I've since switched to the cheaper 5W-30 Formula R just for the slightly more power and economy. Oh and the $20 less on each service :( The thinner oil doesn't give any less protection, unless your engine is worn or you are running insane power (1000hp+).
10w-60 is way to thick for the sky , u should use 5w30 or 5w-40 .
i use to use mobil 1 but since the price is to high i use helix ultra 5w-40 .
if u use thick oil u r going to have higher oil pressure not no more protection thinner oil flows better ( less pressure but more volume ).
