Skyline Oil Pumps....Questions!!
Guest RedLineGTR
OKay i have a r33 gtst i am wondering about the oil pump in them going(failing) at a certain amount of km dont no if it true but someone stated that it was the only downside of the engine itself. With this being true or false dosent really concern me as much.
But what causes oil pumps to stop working or leak enough to destroy the engine. Can i upgrade the oil pump if so what benifits would i get?? Which oil pumps would suit a RB25DET engine.
Thanks Rob
https://www.sau.com.au/forums/topic/24836-skyline-oil-pumpsquestions/
u would never know when the pump is going to pack it but usualy they detiriorate over time although they can just go . keep an eye on your pressure gauge . remember u dont need high pressure to lubricate the engine u need the volume ( its more important than pressure ) and remember the pump has apressure release valve when it reaches a pre set pressure it lets the pessure go so it dont go any higher . on most engines thats about 80 psi but even 30 -40 is enough to keep u r engine healthy as long as the volume is there . i dont know of any upgrades on the oil pumps for rb25s or that the pumps are theit weekness . but remember if the pump stops pumping its only a matter of minutes and the engine is terminaly damaged . ( even 1 minute will stuff up your big ends ) on rb engines number 6 big end will go first . if u race rb26's u need extra baffles in the sump cause as the oil moves around the pick up will run dry and goodbye engine .
What I have heard, and it applies to the majorityof RB engines, is that the heat / cool cycle of the engine causes the bolts holding the oil pump in place to gradually loosen off and oil leaks past the mounting face.
haha
i know this isnt a good explanation
but put it this way
when u do a piss it fows free
imagine pissing a thickshake
not much flow
a lot of pressure
i mean hey its a good enuff explanation
but some pipes in the engine r that small (turbo etc) that a thicker oil isnt going to flow quick enuff and get too hot
sure it protects more but yeah
personally i would use a 10-40 or a 15-40
synth or semi synth
ps dont use helix ultra
made my engine vibrate wickedly and oil pressure was near 0 at idle
and qtr at full rev's
dumped it and all vibration went and oil pressure went back to qtr-4
I just switched to shell helix ultra 5-40 and its great in my r33gtst.
From memory pressure is a tad under 2 when car is at idle (after driving) and goes up to 4 when driving .. more or lss depending on what speed im on ..
Originally posted by RedLineGTR
Okay i noticed that using a higher rating oil Castrol R 10-60w rasied my oil pressure. Is that a good thing or not..would it damage seals if the pressure is too high..or will it damage seals if it is only over filled..
I ran the same oil for 10000km (changed at 5000) and didn't have any problems at all aside for slightly lower power and slightly worse fuel economy. The oil pressure was also higher but it never caused any problems.
I've since switched to the cheaper 5W-30 Formula R just for the slightly more power and economy. Oh and the $20 less on each service :( The thinner oil doesn't give any less protection, unless your engine is worn or you are running insane power (1000hp+).
10w-60 is way to thick for the sky , u should use 5w30 or 5w-40 .
i use to use mobil 1 but since the price is to high i use helix ultra 5w-40 .
if u use thick oil u r going to have higher oil pressure not no more protection thinner oil flows better ( less pressure but more volume ).
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
