Hi Everyone
Sorry to let you all know that we can no longer run our Friday Night Track Driving sessions at Sandown Raceway.
Those of you that have booked and paid for positions on upcomming dates will have their fees refunded.
Of course our weekend and weekday trackdays will continue.
Kind regards
Kev
https://www.sau.com.au/forums/topic/248365-sandown-friday-nights-are-no-longer/
That sucks... I was really wanting to get to these once my car was back. :D
+1
Kev
Was the noise measured and was therefore found to be above a certain db limit before the decision was made to tell you to cancel it?
Was the option of allowing this event to continue with stricter noise limitations in place entertained?
As far as you know was it just a case of a few residents calling up their local authorities saying that it's too loud??
Very disappointing indeed.
Not as if Sandown was there AFTER they moved in.
Its thier own fault!
thats right, they knew what they were getting themselves in to when they bought the house. Farkin nerve to then complain about it. STUPID PEOPLE!
i would love to live next to sandown :D
I used to live a reasonable way from Calder, and on a warm night with little wind or the wind blowing towards my place...
I could hear the top fuellers back in the mid 90's before Bob ruined the party...
I couldnt think of anything better to listen too! Motorsport fans should live near motorsport tracks - pansys should live near a nursery
All those people bought their properties at a much cheaper price back in the day because of that very reason, they were supposed put up with the noise. And now all this crap, after they get cheap property they start bitching. I live 2min from Sandown and it really is not that loud on Friday nights nor is it too late to start complaining or making a big issue out of it, they knew what they were getting themselves into 10 years ago when they were buying their properties.
This is so gay ,
Im with ash on this one .
would the residents prefer we do dounuts in there street, so fkn sick of seeing today tonight and 60 minutes doing stories on " hoons " zooming up and down ppls streets and then wen we go to a race track and not throuh there front fence they still crack the shits and complain.
MASSIVE cruise needs to be organised run it through as many of the nearby streets as possiable. ???
Stuff this , im going to make a few phone calls to the ppl deemed " important " in that area and see where they would prefer us to race .........
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
