Ok. So I was driving on Saturday, and when I gave it a bit (under full boost = 10psi) it would hit a wall kind of like boost cut at 4500rpm for 5 secs then kick into boost again.
Checked over a few things that I thought could be the problem.
1: cleaned afm and plug.
2: tightened intercooler piping and checked for boost leaks.
Nothing worked
Was running and driving fine apart from when I put my foot down.
Then this morning I went to start it up and it wouldn't kick over. So I got a new battery since the one I had was a lil old, put it in and still no dice
All the belts are moving and its just on the point where it wants to kick over, which makes me think it could be the starter motor??
Car was also recently tuned.
Car: Silvia
Engine: Rb25det
Mods include, splitfire coilpacks, turbo back zorst, Apexi avcr, apexi safc, platinum plugs, intercooler, brass button clutch, nothing major.
Any suggestions would be great.
cheers, Ben
https://www.sau.com.au/forums/topic/248397-car-wont-start/
So it's cranking, just not starting? If that's the case, it wouldn't be starter motor. To eliminate that, try jump starting it. If it starts, that'll be the problem. It still would explain the problems under boost.
I would have said coil packs, but you've said their spitfires so that wouldn't be it. Have you had any work done to the car recently?
Check the ignotion system. Is the car getting spark? Is it getting fuel? Are there any plugs that have fallen off? All the vacuum lines attached? I'd check all these first, and then take it to a mechanic.
https://www.sau.com.au/forums/topic/248397-car-wont-start/#findComment-4309946
You need air, fuel and spark to start an engine. Seeming as though you havent listed an aftermarket fuel pump (possibly meaning your still running the 15 year old standard one) under mods that would be the first thing I'll be checking.
https://www.sau.com.au/forums/topic/248397-car-wont-start/#findComment-4309984
try checking the coilpack wiring loom as this can deteriorate overtime which will also cause the car to not start apparently some people who replaced the coilpacks didnt realise that while doing it they might have damaged the wiring as overtime heat caused the wiring to be crispy and would crack easily
https://www.sau.com.au/forums/topic/248397-car-wont-start/#findComment-4311013
Changed the ECU and ignitor module yesterday, neither worked, there was no spark at all. So the problem lies between the module and ECU (as said above, in the harness somewhere).
My thoughts, it could be the resistor?
IS anyone an auto electrician on here or know someone that can come to me as the car doesn't go. For cash :P
https://www.sau.com.au/forums/topic/248397-car-wont-start/#findComment-4311519
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 馃槢 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
