Black R32 GTR, lots of work done...
Had just rebuilt the HKS twin plate clutch a couple of weeks prior.
Brand new rubber all round.
N1 turbos (hard to be 100% but the thing spooled up and rocketted better than any other R32 I've come across).
Tien adjustable coil-overs.
Exhaust, intake piping, blow off valve all japanese aftermarket.
And much more that I don't want to think about at the moment.
Had a front end hit on the right side that did a fair bit of damage.
Is perfect for someone wanting to create the monster of godzillas... get a front cut and away you go.
I just can't afford it at the moment or bare to look at it sitting there any longer.
Open to all offers (idiots will obviously be ignored... even though I was one for doing it)
Get in very quick though!
https://www.sau.com.au/forums/topic/248446-r32-gtr-front-end-accident/
Car still start? Only panel damage?
EDIT: Oh and location please?
Did start after when I tried just quickly before it lost any fluid, but has been sitting for a while now though.
Most of the engine should be salvagable... intercooler, ascociated piping and front end drive train are probably gone.
Took a bit of a hit to the front on the right side.
Was thinking $6000?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
