I was caught making unnecessary noise and smoke from a set of traffic lights in Nerang. The infringment notice has an error on it.In the body type section, the officer wrote sedan instead of coupe. Does this make the ticket invallid, or should I just pay the fine?
https://www.sau.com.au/forums/topic/248455-error-on-infringment-notice/
you should write him up a ticket for not being able to tell the difference
id just pay it dude
what else can you do? take it to court? and use "my car isnt a sedan" as an excuse for your infringement?! then court cases just for that?
just be done with it and dont do it again.....
I've read somewhere that that sort of thing would make a ticket invalid if there was more than three errors
If you notify them they will confirm other details with the officer that issued the ticket and correct the ticket and issue another infringement.
I'd suggest paying it , unless of course there is more than 1 error that is quite substantial the officer in this case doesnt know his cars and will simply tell the road authority that he thought it was a sedan of sorts and have his screw up fixed up :D
same thing used to go with birth dates and names if u are asked for your name dob etc and u tell them incorrectly they'll get you for giving false information however if the police officer makes the mistake and misreads misinterprets or guesses something they can turn around and fix it up later on :D wierd how that works huh
ummm...check your rego and what it classes you car as. Sometimes they class them as a coupes only if the back window lifts up with the boot.
then again it could just be a massive mistake...put it this way i drive a sedan and its registered as a coupe...dont know how that happened.
i had a similar incident. got a parking ticket for parking in a bus stop for 10mins. under Car Description, he wrote grey nissan coupe. MY car is dead set BLUE with a PURPLE shade (not remotely close to any sort of a grey) lol. i was going to take it to court and argue technicality, and also attack the ability and reliablity of a person to issue fines, when he cannot differentiate between blue and grey lol. BUTTTTT i had exams and didnt have the time to pursue it, so i just paid it :D
^^^ A lot of people have that degree of colour blindness.
Main Entry: se·dan
Pronunciation: \si-ˈdan\
Function: noun
Etymology: origin unknown
Date: 1635
1: a portable often covered chair that is designed to carry one person and that is borne on poles by two people
2 a: a 2- or 4-door automobile seating four or more persons and usually having a permanent top — compare coupe b: a motorboat having one passenger compartment
Don't be silly, pay it.
English.. it's my language.
Edited by madbung
I once got booked at Wentworth Falls doing 60Km/Hr in a 50Km zone, but Mr Plod wrote out the ticket with the Number Plate of the car in front of me (and not mine).
I took it to court, just wondering if I could get off on a technicality. But alas, the magistrate determined that because I was the driver of the car that was speeding, I still had to pay and lose pts.
I must admit too that I represented myself; which means that I had a fool for a client!!!
Tez
He could have written "helicopter" in the vehicle panel and it wont make any difference.
In court technical details do matter, but it can't be something tiny that will get you off on a "technicality".
it is a sedan mate. but sure take it to court. it will be awesome fun when you try to explain it to them. video and youtube it.
and even if he wrote sudan under body type it wouldn't matter. in no way does it have any impact on the validity of the ticket.
Take it to court and they will thank you for pointing out the error. They will then correct the error and charge you a court fee and probably an increased fine for wasting their time..
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
