hi guys selling as i heave a work ute now and already have another weekend car, so no longer gets used.
1995 r33 seris 1.5
rb25det
76,000kms
Car is black with 3 of the tiniest trolley dings. Rest of the body is straight as and the paint is mint just gave it a cut and polish, looks new. Has m-spec front bar fitted
Lowered with king springs,
has a pod filter,
stainless steel split dump screamer,
full 3in brand name exhuast which sound nice and deep but not defectable.
19in mags, brought 2months ago 3 tyres have real good tread one tyre needs replacing soon.
Automatic- shifts suprisingly quick through gears.
Factory LSD diff
Velour interior mint condition as new
steering wheel has that minor peeling paint problem which i common.
Registered in SA
Sony GPS
TV screen remote control, with 6stack sony cd player in boot
The series 1.5 r33 came out with the series 2 motor, series 2 rear spoiler and driver and passenger airbags and a few other goodies.
This car has been very well maintained and buyer wont be dissapointed .
Dont need to sell car just offering it for sale basically to make some space in my driveway.
will take more pics of interior and engine bay
After $10,400
Can drive car closer to adeliade for a serious potential buyer to view/test drive.
Ph: 0434827285 Located in S.A bout 1 hour south of adeliade
Chris...
Edited by CTRcustompanel
https://www.sau.com.au/forums/topic/248461-fs-r33-rb25det-76000kms/
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
