Gday crew was playin with my car had the front bar off and noticed this. It looks like something to reduce intake noise some sort of plenum to stop surging noise out of the stock air box like falcon xr turbos have on the side of there intake. thing is i no longer run an air box just my pods. is there any point me having this gear in here still? or is it just wasting space?
In the pics you can see my set up and where the stock air box would hook up to the vent below the headlight, drop down under the car and into the box that is completely sealed actually has no opening aside from the pipe.
Anyone got info on exactly what it does and weather i need it now or not.
thanks crew
Dion
https://www.sau.com.au/forums/topic/248468-32-gtr-standard-air-intake/
i pulled the box and connecting brackets off. then did a 180 with the elbow pipe so that it could collect some cold air from the front bar vent. From memory i did some cutting/reshaping of the end of the elbow to aid air entry.
yeah sounds like a plan. nothin like a cheap cold air intake!
Pretty sure the gear is for noise suppression for the BOVs (look at where the air channel runs to the drivers side and follow it along). They're still quiet enough with it removed. I run the stock airbox and have removed it to help with airflow.
Like teh Baron says it is a resonator.
But do yourself a favour. Use the remaining pipework to help get some cold air to the pods.
Works like this:
Beneath the headlight there is the air inlet which used to feed the stock air box. The resonator is connected underneath it.
Use this connection to grab some air fron the front left hand side of the front bar.
That way when you get sick of your pods sucking hot air from the engine bay you will have a ready source of cold, pressurised air. :(
Works like this:
That way when you get sick of your pods sucking hot air from the engine bay you will have a ready source of cold, pressurised air. :)
im down like a frown with a clown! its like nissan said "hey we will put this silly box here to get rid of some lame noise but when people with pods come along they can turn it into a cold air intake, we are so crever!"
oh yeah :D
thanks crew
Dion
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
