  • 4 weeks later...
They will always be suss about a hi mount manifolde and turbo arrangement
Although aslong as (i am assuming its external gate) the wastegate pipe is plumbed into the main exhaust you sould be ok with with that, also if you can get an inclosed intake box as they will crack a wobbly about a open pod filter set up, if its possible and also if it has not been done already plumb back your BOV
I have had a rather suspicious looking skyline (matte black with huge wheels lol) and usually was able to go out without getting harassed, but its all in how you drive the car as they will soon learn your car and it will become a vehicle of interedt if your car has been reported/seen doing stupid shit, thats when they pull you up for no reason and go defect hunting, also if its not a local car they will pull you up and suss it out and maybe keep an eye out for it for a few weeks or so
But if the vehicle is ok and you don't drive like a lunatic you should be fine
Cheers Marty
  • 9 months later...
mate generally its not the car you drive but how you drive
with that said, if you're cruising around a fully stripped 32 with a cage, straight thru pipes, and thats 2mm off the ground - yes you will get pulled over regardless
'Tis much worse after dark > or should I say, out of work hours...
'Tis worse near a maccas, KKs or KFC...
'Tis better if wearing a pin-stripe suit...
'Tis better if you look as old as me...
Gotta love the grey hair Terry, I laugh at the younguns havin a moan about how many times they get pulled over.
How many times have you been driving when a cop pulls along side, looks at you then shakes his head and drives away.
I luvit. :(
I luvit. :(
Hehe Noel,
I owned my R33 GT-R for 2yrs and a day. I have owned my R34 GT-R just 1 month short of 3 yrs.
Despite my massive tip, I've never been pulled over - not once. RBTs don't hassle me. I wear a beret now to hide some of the grey haha. No, I'm not gunning for a spot on Mythbusters hehe.
I admit tho' that if I went out a lot at night, it would be a different story.
I don't have to see 'blue'; I can smell it!
Cheers, T
C'mon Craig & Noel, sensitivity doesn't get calloused with age ya know.
My optimism only extends as far as this...
"I might be losing my hair on top; but at least it regrows thru the ears and nostrils" hahaha
What have we here? A collection of the DRIEST WIT SAUers on the forum!
...all on this backwater called 'Skylines A Target'
I'll always remember your contribution to "Which Mods To Do In Order" Craig lmao = one of the best posts ever!
BTW where is the OP?
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
