Yo, mines on there too mate (r34 gtr)
You car is one of the most tasteful r32's ive seen so nice work; actually did your dad do the mods or buy it that way?
Your not on your p's are ya
wow.. i love that car. we bought the car that way but it had engine problems, once we fixed its coil packs it was running on all 6 cylinders, then we fixed its missfire so basically its perfect now.
i am on my p's but im keeping it til im 21 plus im doing the occasional track day
Thx man, ahh i see; good thing you got it fixed up but i would be so annoyed that you cant take it out whenever you want. During the day should be ok.
track day would be fun! Your face is familiar, you live in northern subz
Its OK, when he wants to take it out ill drive it for him, he can sit in the passenger seat and enjoy it. LOL
It wasn't the coil packs, it was the AFM's needed cleaning, the ignition module, plug heat range and gaps to be closed up a little.
Looks like the cars dropped to 4th, come on guys get behind the car you all love and get a Godzilla on the cover.:P
Nice car Johnny.
Edited by GTRPSI
Looks like the cars dropped to 4th, come on guys get behind the car you all love and get a Godzilla on the cover.:)
Nice car Johnny.
Lolz! thanks mate, dosent look like ill be able to catch up but as long as im in the top 10 and beat that bloody ford.
Were all counting on you to be the cover car! i dont wanna see anything other than a nice JDM win.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
