Hi guys,
I got a wheel alignment done yesterday and found that the rear camber is out, (-1.4 LHS/ -2.4 RHS) and that the adjustment is maxed on the stock bushes. I was quoted $90 by pedders for their urethane camber kit compared to $253 dollars for the super pro kit! He was as surprised as me, and as far as we could tell the kits were the same. I know SK's whitline group buy is cheap but not this cheap, so i was wondering if anyone has had experience with the Pedders camber kit or can maybe explain why the difference is so great.
I dont want to pay a low price for shit quality only to have them replaced in 6months time.
Thanks in advance people.
https://www.sau.com.au/forums/topic/248508-pedders-suspension-bushes/
Check out the for sale section, I'm sure that I've seen someone selling new whiteline rear camber bushings there.
I got my front whiteline camber and castor bushings on ebay from Online Performance Autos.
Rear ones are only $135+postage
http://cgi.ebay.com.au/Nissan-Skyline-R32-...1713.m153.l1262
Not TOO much more than $99, but a lot less than $253 and at least you know the Whiteline bushings are good quality.
If you're going to pay to get them fitted and adjusted, you might as well do all the bushings in one go, unless your front camber and castor isn't out too much. My front was way out, but rear was fine so I didn't do the rears, but for the cost of labour I sort of wish I'd done them in one go.
  • 2 months later...
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
