Hey All,
I've recently had my car tuned and aren't sure if this is what I should be getting. I've read other posts where people have been achieving more power on less boost and similar mods.
My car is an R33 SII
PowerFC
Kakimoto catback exhaust
Catco Hi Flo Cat
FLYN Bellmouth Dump/front pipe
Stealth FMIC
Solenoid Bleed Type Boost Controller
K&N Panel Filter
All else is stock
Getting 189.5kw at the treads with 13psi. The tuner also said if I had a Wolf3D, I'd be getting around 210kw.
Any info is appreciated.
Thanks heaps.
https://www.sau.com.au/forums/topic/248509-dyno-graph/
  • Replies 53
Popular Days
Posted Images
Thanks heaps guys. I appreciate the feedback.
I'll go back and ask for the AFR graph when I get a chance. My tuner said he's saved the maps so it shouldn't be a problem.
May as well ask for a torque curve too.
https://www.sau.com.au/forums/topic/248509-dyno-graph/#findComment-4311448
Has anyone else noticed that the boost drops off from 13 to 10?
I just got mone retuned with a stock turbo and injectors i have a walbro 255 and a sard fpr also a FMIC and a full exhaust from the turbo back with a microtech lt10's and am having the same issues with boost. Running 12 psi it spikes to 13 then bleeds right back quickly to 10 psi but i still made 203.6rwkw.
I would say your power is a little off the pace or mine is high i am not sure.
Although my power curve is more agressive then this. Maybe my turbo has been high flowed?
Edited by super_s13
https://www.sau.com.au/forums/topic/248509-dyno-graph/#findComment-4311793
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
