Hi Paul, welcome to sunny brissy where it thunder storms every second day and floods my garage.
A far as I know, if you box in the pods so they're sealed you'll be ok, bov's need to plumb back with afm. Just keep the car away from the gold coast on weekends if you're treading a fine line. I got pulled over heaps of time with my bluey with pod, atmo bov and autronic only question raised was my lack of interior trim which I was told to put back in as soon as you can if you please. Cops seem to book you here more on attitude, so be courteous and honest if you're pulled over, most of the ones I've dealt with have shown an interest in the car, making sure it wasn't stolen and i wasn't on the turps.
Oh yeah, exhaust shops. CES in meadowbrook is expensive and top quality. If you're northside you could try rob bliss in geebung, and cleveland way try the muffler shop (used to be wooloongabba but moved recently) Or just go for a drive down moss st in slacks creek.
your only allowed one intake mod.
NEVER heard of that before. I don't beleive it to be true either.
As mentioned, pods have to be firmly secured by a bracket (zip ties arnt safe apparently). You do not need a heat shield for pods in QLD however its better for you to have one as youll get lower intake temps.
BOVs have to be plumbed back. You are allowed dual ports as long as one side is plumb back and it is set to that on the street. Despite common beleif they arn't illegal due to emissions but rather making unessecary noise.
Any questions you can call the Queensland Transport modifications line on 3253 4851
True words that- pod must also by dry-type.
If too much induction noise can be attributed to the pod then it will be classed as a defect also.
Exhaust is 92.2Db at 4000RPM@6m-this needs to be checked as not 100%- about 95% sure tho
As to the legality of BOV- atmospheric venting which is unfiltered is illegal in Qld.
Due to;Air from BOV or Air Bypass Valve contains a small percentage of highly pressurized recirculatory gases from breather & Turbo charger which are fed back into the intake & may contain unburnt engine gases,oils, vapours, etc and therefor Atmo's are in contradiction with Vehicle Emisions standards & the EPA Act.
Great advice to ring Qld Transport tho-bravo on that 1- complete with ph# :D
other great advice up there is be polite & helpful even if your pissed off- if you aren't then you will find out the definition of an 'Attitude Adjuster' in the Qld police vocabulary lol
Yes but theres no emissions testing for it. You get done for it because of noise.
It's also not 92.2DB it's 90db for stationary cars and 77/78(depeding on car) for a vehicle in motion. This is of course under test conditions. You can read about it and all the testing methods at http://www.comlaw.gov.au/ComLaw/Legislatio...FRLI+Mar+06.pdf
Other ADR info http://www.infrastructure.gov.au/roads/mot...adr_online.aspx
Edit: Also im not sure about that dry type pod filter thing.
Thanks for posting the correct noise levels, respec
Cheers guys, really good information.
Im originally from Canada and we dont have any rules like the ones here. We only have a db rule on exhaust, have to pass emissions and safety test so all this is new to me. Ive been down in Sydney the last 2 years trying to find out everything I could but the RTA is not as helpfull as one might think. I already have a turbo back exhaust and fmic, I even got the exhaust real quite and stealth just to avoid attention. Ive heard the rules are a lot more leanient here and love the sound of a real deep exhaust with a BOV, I know the BOV does little to none for power but love the sound. So Im thinking bout gettin a cannon on the back of the exhaust and the BOV and would love any suggestions on either.
Thanks again
f**k these rules are bullshit, fair enough if it impacts on safety but shit like bov noise and induction noise is f**ked in the head. just because some stupid old lady or some retard gets distracted on the road by noise if they are that bad then they should be on the road. makes me f**king angry when there are a million times worse things in the world that need attention.
sorry for off topic but on topic dont all mods need engineer cert now?
What really shits me to tears is that you could be pulled over for exhaust noise and a Harley goes past on 1/4 throttle and is SOOOO noisy, but the cops do nothing. I don't think I have ever seen a Harley that would be under the 90dB level. Most are over 100dB!!!
+1 FOR THAT!
  • 10 months later...
Under the road rules for QLD there is nothing that states 1 intake mod. There is no restriction on FMIC as long as it is correctly installed.
Anyone who can't link to the contrary on QLD Transport but states it is a liar, we don't insure defective vehicles.
what do the cops look for?
Loose pod filters. Has to be secured to body.
Screamer pipes.
Exhaust Db.
BOV is recirculating.
oil drips/leaks
Gauges above the dash line.
Carbon fibre bonnets.
They are the ones I have been checked for 3 times in the last 6 months.
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
