hi all
my stock turbo on my r33 shit itself and its time to go better just wondering what would be best for a stock motor on the in side im doing hi mount, custom intake, fmic, ecu, injectors and pump if needed.
would a gt35/40r .82 rear be to big
some ideas and info would be great thanks
  • Replies 93
The HKS GTRS has always had good results.
The A'PEXi AX53B70 is another one, its basically the equivelant to the GTRS
Both are good for the 250 to 260kw range.
You could also highflow your standard turbo and expect around 230 - 240kw
These will all bolt onto the standard manifold and won't give you lag and then a massive wave of power like the GT35R will on a 25.
Edited by MintR33
hi all
no need to go high mount bud, waste of time and money on an internally stock motor. and a 35/40 may very well be the worst turbo choice you could make on an internally stock engine. as has been said already, a gtrs bolt on kit would be prime, if your after a bit more poke go a 3037. if your workin to a budget, get a highflow stock turbo
Buy my KKR430! I need it gone!
Check my link out http://www.skylinesaustralia.com/forums/Br...l&hl=kkr430
what brand is it mate.
a mate has got a new t04e for sale what kw would u see with that
I'd recommend the HKS GT2530 for a good balance between power and response - just not the price!
The HKS GT2530 Kai Bolt-up Kit for the R33 cost me about $3.5K to import in the last month or so - not a cheap option but works for me and exactly what I needed :-)
why do u say no need for a hi mount
I run the HKS 2535 and puts out some good power!!!!
You also have to remember that you can only boost so much on a stock engine anyway so there's not much point pushing anything past 14 - 15psi. That'll get you around the 230 - 240rwkw mark!!!!! Then fuel becomes and issue. U'll need bigger injectors.
highmount is a waste of time...
1 - cop magnet
2 - on an internally stock engine your not going to be putting out numbers that make the standard manifold a real restriction
3 - cop magnet
4 - expensive for virtually no gains
i'm running an hks 2835 pro s - expect 260-280 rwkw's depending on motor/mods/tune with near stock response.
you will need ecu, injectors, afm, fuel pump, fmic and clutch minimum
1 - cop magnet
3 - cop magnet
i got one sitting around i got cheap awhile ago so thats why i was gonna put it on
whats the hks 2835 pro s worth and whats the specs
what would u pay for a hks 2535 turbo custom dump and front pipe and all oil and water lines made to suit a r33 second hand min shaft play. what would one cost for a rebuild any way mate
