hi all
my stock turbo on my r33 shit itself and its time to go better just wondering what would be best for a stock motor on the in side im doing hi mount, custom intake, fmic, ecu, injectors and pump if needed.
would a gt35/40r .82 rear be to big
some ideas and info would be great thanks
  • Replies 93
The HKS GTRS has always had good results.
The A'PEXi AX53B70 is another one, its basically the equivelant to the GTRS
Both are good for the 250 to 260kw range.
You could also highflow your standard turbo and expect around 230 - 240kw
These will all bolt onto the standard manifold and won't give you lag and then a massive wave of power like the GT35R will on a 25.
Edited by MintR33
hi all
no need to go high mount bud, waste of time and money on an internally stock motor. and a 35/40 may very well be the worst turbo choice you could make on an internally stock engine. as has been said already, a gtrs bolt on kit would be prime, if your after a bit more poke go a 3037. if your workin to a budget, get a highflow stock turbo
Buy my KKR430! I need it gone!
Check my link out http://www.skylinesaustralia.com/forums/Br...l&hl=kkr430
what brand is it mate.
a mate has got a new t04e for sale what kw would u see with that
I'd recommend the HKS GT2530 for a good balance between power and response - just not the price!
The HKS GT2530 Kai Bolt-up Kit for the R33 cost me about $3.5K to import in the last month or so - not a cheap option but works for me and exactly what I needed :-)
why do u say no need for a hi mount
I run the HKS 2535 and puts out some good power!!!!
You also have to remember that you can only boost so much on a stock engine anyway so there's not much point pushing anything past 14 - 15psi. That'll get you around the 230 - 240rwkw mark!!!!! Then fuel becomes and issue. U'll need bigger injectors.
highmount is a waste of time...
1 - cop magnet
2 - on an internally stock engine your not going to be putting out numbers that make the standard manifold a real restriction
3 - cop magnet
4 - expensive for virtually no gains
i'm running an hks 2835 pro s - expect 260-280 rwkw's depending on motor/mods/tune with near stock response.
you will need ecu, injectors, afm, fuel pump, fmic and clutch minimum
1 - cop magnet
3 - cop magnet
i got one sitting around i got cheap awhile ago so thats why i was gonna put it on
whats the hks 2835 pro s worth and whats the specs
what would u pay for a hks 2535 turbo custom dump and front pipe and all oil and water lines made to suit a r33 second hand min shaft play. what would one cost for a rebuild any way mate
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
