I think the GT-RS has a way to small exhaust side for an RB25. Massive back-pressure up-top.
The ultimate bolt-on responsive turbo for the RB25 has gotta be the HKS GT2835 Pro S bolt-on kit.
http://www.hks-power.co.jp/products/turbo/...o/ac_gtpro.html
It's pretty much the spot-on size in both the compressor side and the turbine side.
  • Replies 93
i have to agree there...
mine hits full boost at 32-3500 and stays on till my 7400 redline...
i have an exhaust cam gear to bring it on earlier (at the exoense of like 10rwkw up top) and the car is an animal
Guess depends on if you wanna drive round or sit at home jacking off over dyno sheets...
You could combine the two....
Maybe that's why some people carry a dyno sheet in the glove box, all makes sense now!!
Just reading through this and you need to ask yourself do u want responsive power or laggy as hell.
I agree with hks gtr-s or 25/35 (30) for responsive power although may not pull the higher figures.
what a crock of shit.
i have a 3582r with a .82 rear and and i can see 24 psi by 4k
most of the other figures quoted from the other turbos in this thread are all full boost somwhere in the 3k - 3.5k range
and you will find 90% of gt30 size turbos are all gonna be around the 4k mark as well.
so what do you call laggy as hell?
imo do it once and do it properly
a gt3582r/iw will fit low mounted no worries, running at 15 psi you will make between 250 - 270 rwkws.
if the motor gets rebuilt then up the boost and make 350rwkws.
the thread title has been answered you make up your mind what your looking for.
remember guys you can build a mental set up and just detune it for reliability.
i have a GT-RS and a GT3040 and there is no doubt the GT-RS is the more responsive turbo. increases in throttle application generally you get more instant joy out of the GT-RS.
however, the GT3040 (aka GT3082) isn't too shabby to drive around, it needs a few more revs onboard but makes much more power once it is going. ultimately the compressor will be choked by the turbine on this version but it is a pretty good thing. so i am guessing it will feel not too dissimilar to a GT3582 at 75-80% of its max.
personally, i think something that can make 270-300rwkw for a rear wheel drive car is the best bet. this is about the limit of traction on road tyres and inside a power level for keep the stock engine chugging along for a while with good tuning.
so that means GT3076 sized turbo if funds permit with the addition of a merge collector manifold you can bring the boost threshold down.
so many people say that turbo is the go mate what u mean by merge collector manifold
How about the HKS GT2540? I don't see many people talking about this turbo. It's a direct bolt on as well to the RB25 Engine.
Probably because they are the laggiest turbo for the power they make and the cost to obtain them and I'm not sure HKS even make them anymore so the odds are that one you buy will be many years and kms old.
GT3076R as stated, is ftmfw
what are they worth mate
i have nfi to be honest, best to find one in kit form so its all nice and easy to bolt up , iv'e seen them as low as $1200 for the rb kit 2nd hand (the turbo is easily rebuildable). dr drift was looking into getting copies fairly cheap , it might pay to email him (he made 300+rwk with one, its in the rb25 upgrade thread)
Edited by toffy
here ya go , his exact words on his :thumbsup:
Want to make a few changes, upgrade radiator and maybe some coilovers, and the gearbox is whining after the weekend... Will try and make next day at Basky!
As for the L2, yes it's an EXACT copy... we've completely pulled the turbo apart and put it side by side with a genuine L2 and you CANNOT spot the difference...
Response on the 25 is pretty stupid, and I haven't even hooked up the VCT!! More to be had :D
Pulled the intake pipe off this aftenoon, and with over 1000km now on it (most of it HARD) there is absolutely no signs of wear at all!
I'm negotiating direct with manafacturer to try and get these in a bit cheaper, but I'm going to have to order min 10 pcs!
Edited by toffy
Assuming he does not take it to drag/drift/track days every weekend and keeps away from the rev limiter and a host of other variables that will kill an engine that is on the limit.
My 25 only sees drag/drift/limiter... But I do concede it seems abnormal for a stock 25 to make 305 rwkw reliably with 25 psi copy L2 and other budget bolt ons!
trust td06 l2 20g :spank: their maximum efficiency is right on the limit of a stock rb25 imo
Hell, even push them past their max efficiency... they just sing!
what are garrett 3082r like are they more laggy then a 3076r
turbo is rated at 600hp front cover is Ar .70 and .63 rear for quicker spooling
what would u pay for a second hand one
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
