Hey guys,
I've just recently had a R32 GT skyline (RB20det). And I have been taking up drifting. Ive found that that stock turbo aint enough go. So I've been trying to look for a decent turbo with enough go. Im looking for a turbo bigger then the origanal one, but not too crazy. I'm looking at the price range of about $2500 tops. Not looking for a FULLY HETIC SUPER FAST turbo. Just something to nice and bit bigger then origanal. Would also like to know where to get it from. I live in QLD/Brisbane.
Cheers, Nick.
https://www.sau.com.au/forums/topic/248572-what-type-of-turbo-should-i-get/
have you thought about other associated expenses?
fuel system, intercooler, exhaust, engine management?
much besides, here is a massive topic
http://www.skylinesaustralia.com/forums/Rb...tml&hl=rb20
all about turbo upgrades on rb20s. you can learn a lot about the power figures, and other mods you might require.
First of all Nick congrats!
Anyone can turn the wheel and stab the throttle. Doing controlled opposite lock 360's around a cone is harder than people think.
And you really seem to get the hang of it in the end.
:D And for god sake DO NOT go out and do it on the street, some people think just because they have done one skid pan day they think they are D1 drivers.
Keep it up!
Keep it up!
Thanks man.
Yeah, I'm only 15, so i wont be doing it on the streets. Hense being on the track, its supposed to stop me from doing it on the streets. Which is what it will do. Thanks for the support.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
