Age: 12 y.o
Condition: All parts are in working order
Contact: PM with any questions
Comments: I need this stuff gone, im letting it go for cheap.
R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - $200
R33 GTS-T Series 1.5 Front Upper Control Arms - $50
R33 GTS-T Series 1.5 Front Castor Rods - $50
R33 GTS-T Series 1.5 Front Wishbones - $50
R33 GTS-T Series 1.5 Front Brake Hubs w/ Lines - $100
R33 GTS-T Series 1.5 Front Struts w/ Springs - $100
R33 GTS-T Series 1 Inlet Manifold w/ Throttle Body - $50
R33 GTS-T Series 1 Ohlins Rear Struts w/ Dampening Adjustments & Springs - $100
Pictures can be found at:
http://www.skylinesaustralia.com/forums/R3...ts-t238267.html
https://www.sau.com.au/forums/topic/248578-fs-r33-gts-t-parts/
Following items are free :D , pick up only....
Series 1.5 ABS Unit
Series 1.5 Window Washer Bottle x 2
Series 1.5 Overflow Bottle
Series 1.5 Brake Booster
Series 1.5 Clutch Master Cylinder
Series 1.5 Passenger Side Power Window Switch
Series 1.5 Front Windscreen Wiper Motor
Series 1.5 Rear Windscreen Wiper Motor
Series 1.5 Rear Brake Caliper (Side Unknown)
Series 1.5 Rear Brake Rotors
Series 1.5 Pedal Assembly (Clutch, Brake & Accelerator w/ Throttle Cable)
Series 1 Turbo Heat Shield
Series 1 Rear Spoiler
If you want any of these please PM me or SMS me on 0413 351 827
Thanks
  • 3 weeks later...
DaGr81 - yeah mate just give me a call in the morning and we can arrange something
i leave home around 4pm to go to work thats all
**R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - Sold
Only the sub frame remaining - $50ono
Series 1.5 ABS Unit
Thanks
Hi I was wondering would you have the front bumper bar.
Thanks
sorry man i woke up a bit late i work in the city monday - thursday and can pick up after 6pm any of those days, other wise friday afternoon after 2pm, let me know which is best, once again sorry :happy:
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
