as title says im having dramas with my pro fec 2... i have the 'on' bit of the boost soliniod going to the intercooler, and the othe one going to the waste gate... there are 3 other hoses that ive blocked off... if any one has any pics of there set up can they plz post up... its all in, and runs on stock boost on high, and low ive set the limiter at 4 psi to semi kelp me save fuel. i just cant seem to wind it up :D ive tryed all the settings in different levels... cheers!
https://www.sau.com.au/forums/topic/248607-dramas-with-greddy-pro-fec-b-spec-2/
I have no idea how the Greddy profec works - I have the Jaycar EIBC myself - but if no-one else contacts you with personal knowledge here is a link with quite a bit of information:
http://www.thumper300zx.com/z32/profecb2/profecb.htm
on the stagea, we have taken the feed from the compressor (pre-intercooler) to the NO port (as listed in manual and is the one next side around from the COM port) then the COM port hose to the actuator.
your hose labeled "going somewhere down the front" appears to be plumbed in after the intercooler.
on the R33 we have used a feed from the plenum (T'ed and feeding) to the bottom of the ext wastegate and to the NC port. the COM port hose goes to the top of the wastegate.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
