For sale is r32 gtst coupe 1990
5 speed manual
120k on the clock
black
turbo back exhaust system
supplied with spares and bits a peices i have lying around
sold with steel rims
front mount intercooler
NEEDS
repair of drivers side seal
paint front end
needs rear bottom seat
needs 2 front door trims
cluster surround
passenger headlight
paint passenger door
GIVE ME A CALL IF U WANT TO CHECK IT OUT
0402090079 LOCATED IN RESERVOIR
$3500 no money owing on the car and not written off in anyway
Edited by SXC_R33
wow this is really poor condition
willing to part out some things
Edited by blockasR32
so its a complete driveable car? with motor and gbox? i cant believe u havnt sold it already..if u were in adelaide id give 3500 4 it today. perfect for a project car or track car.... im lookin 4 a s13 rolling shell for a track car and they go for 2 - 3 grand!!!
  • 1 month later...
Hey,
Interested but I can't see how I could get it. I wouldn't mind flying over, but I just don't have the money and I bet I wouldn't be granted a loan. Nonetheless, I'd like to know a few things about the car, so if I can wrangle something I know it'd be worth it.
Was it involved in a front end collision? It has a new quarter panel and a missing headlight, so I'm assuming it was. Has it been checked for chassis/suspension damage? I personally wouldn't care if it had a bent control arm or something, as long as I could drive it back to Adelaide and the chassis is ok. I wouldn't mind pics of the car from exactly side on, each side, with the front wheels dead straight.
What's the history of this car? Was it previously NA, auto etc? Is it 4stud or 5stud? And what's the mech. condition of everything? Does it go hard? Blow any smoke? Make any unusual noises like whines, scrapes, thumps, hisses? Obviously for the money the car isn't perfect but I want to know exactly what's going on with it before I get my hopes up. Any chance of some engine bay pics? And maybe some around the suspension to make sure it's all good?
Cheers,
Eli
Edited by archangel62
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
