For sale is r32 gtst coupe 1990
5 speed manual
120k on the clock
black
turbo back exhaust system
supplied with spares and bits a peices i have lying around
sold with steel rims
front mount intercooler
NEEDS
repair of drivers side seal
paint front end
needs rear bottom seat
needs 2 front door trims
cluster surround
passenger headlight
paint passenger door
GIVE ME A CALL IF U WANT TO CHECK IT OUT
0402090079 LOCATED IN RESERVOIR
$3500 no money owing on the car and not written off in anyway
Edited by SXC_R33
wow this is really poor condition
willing to part out some things
Edited by blockasR32
so its a complete driveable car? with motor and gbox? i cant believe u havnt sold it already..if u were in adelaide id give 3500 4 it today. perfect for a project car or track car.... im lookin 4 a s13 rolling shell for a track car and they go for 2 - 3 grand!!!
  • 1 month later...
Hey,
Interested but I can't see how I could get it. I wouldn't mind flying over, but I just don't have the money and I bet I wouldn't be granted a loan. Nonetheless, I'd like to know a few things about the car, so if I can wrangle something I know it'd be worth it.
Was it involved in a front end collision? It has a new quarter panel and a missing headlight, so I'm assuming it was. Has it been checked for chassis/suspension damage? I personally wouldn't care if it had a bent control arm or something, as long as I could drive it back to Adelaide and the chassis is ok. I wouldn't mind pics of the car from exactly side on, each side, with the front wheels dead straight.
What's the history of this car? Was it previously NA, auto etc? Is it 4stud or 5stud? And what's the mech. condition of everything? Does it go hard? Blow any smoke? Make any unusual noises like whines, scrapes, thumps, hisses? Obviously for the money the car isn't perfect but I want to know exactly what's going on with it before I get my hopes up. Any chance of some engine bay pics? And maybe some around the suspension to make sure it's all good?
Cheers,
Eli
Edited by archangel62
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
