Hey guys, the skyline has been off the road for a while (6mths) and now wont start. Battery was flat and not looking like holding charge, but has now been replaced. Car is cranking over but not really looking like starting. I've made a visual inspection of all the fuses (they all look fine), but other than that I'm not really sure what to check. I'm guessing the fuel would be well and truly stale by now, but surely the car would still start? Failing any tips to get that car started, can anyone recommend a decent mobile mechanic (adelaide area) lol.
Edited by mind_riot
https://www.sau.com.au/forums/topic/248611-help-r33-wont-start/
Hi!
Im not shure how technical you are, but the first thing I would have checked when a car is turning but nothing happens, is:
1. Check that you have fuel pressure
Different engines has different ways of checking this....
2. Check that you have a spark.
Normaly you could take the plug out and hold it against metal, and turn the ignition, and a spak should apair. But remember to eather disconect fuel line or disconect all sparkplugs.
And if you have all of this, it should start, and it may be bad fuel or timing is way of or something like that.
Probably not this but i had a similar problem, came up out of more or less nowhere. Turned out to be my CAS giving me a hazzle, changed that and the problem i slong gone :D
Other then that, as stated, check spark (I'd start with that) and then fuel, maybe a fuelfilter change or the pump gone bad?
Cheers!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
