Hypergear Tr43 Dyno
WYTSKY
 Share
hey guys, got the car tuned last week, really really happy with the response Sam put into it down low, but I think a little somethings missing uptop...
or do you guys think this is about right? just a thought... was a 32 degree day and Sam's weather machine wasent working, so we had to try to manually correct the graph, as well as this, i think the timing was retarted back a little.... the next thing Sam and I were planning on doing was cams, but as I am a student there is a decent amount of time between each mod being put in :)
mods are in the sig, but main things engine wise are:
hypergear tr43
a little t piece manual boost controller set at about 15-16psi
nismo 740cc injectors
bosch pump
z32 afm
Exhaust cam gear
hybrid intercooler
turbo back 3 inch zorst and new metal cat
powerfc + commander
pod + cai + heatsheild
it is really responsive IMO and pretty fun to drive... just goes a little flat at the top.
max of about 8~15 knock, got a little missfire though :D
was that with cams? was that on a rb30/25?
dont forget, was on a pretty hot day, im sure the Garrett item would be better, but, i think Tao's R&D is coming along well :D
appart from response, what do you think of max power? little low for a 450hp turbo? or does making more response lower the overall max kw?
Thanks for the input.
Adam :)
215RWKW @ 16psi?
My inefficient highflow made 250RWKW @ 16psi.
So yes its a bit low. And certainly hits the wall at 5000rpm.
If you expect to get decent results buy decent gear. Otherwise you will just be annoyed with yourself for not spending the extra $$$ and end up doing things twice.
The cheapest decent turbos are Garrett ones, anything less than that is a waste of money.
RB25, stock capacity, stock head :)
Peak power isnt too bad, its roughly what you should expect, maybe a tad more if it didnt nose over in the upper RPM (could be time for a better actuator)
damn... but you guys are using the better stuff i guess :D in terms of the actuator, we changed the one that was one there (7-12psi) because it wasent holding.. to a 14-20ish psi one but used the the bleed valve for the extra 1-2psi.
I understand why your saying that nytsky, and you probably are right, I dont want to get into an arguement about should have spent 1600-2000 instead of 850. I also did think it was quite low, but before I get fried, ponder this before responding:
I would have saved up the money, however the stock turbo I put on the car blew after about 9 months ( oil seals). Im a student, its hard to save and takes time, I could find standard turbos out there for ~350, but then they could just root on me in another 6 months, after all, they are about 14 years old. so I could not have a car for 2 months and save or buy something from new that would atleast get me going (without blowing straight off- eg ebay crap) and MAY be desent to make power...im still happier with my choice then using Melb's shitty public transport system.
Adam
that is a once off mate.
there are MANY people making alot more power with those turbo's.
the fact is, 215rwkw can be made with an R34 GTT stock turbo at like 12 psi..
so it's got nothing to do with the turbo.
soemthing else is going on there..
you did say something wasn't set up on the dyno properly.
go back again when it is all fixed.
and you have sorted the misfire.
and finally, dyno is a tuning tool etc etc..
a CA18 on NS made 255rwkw on 22 psi using a hypergear turbo.
and ofcourse the whole forum went on and on about how it was Trents Dynapack dyno and it was happy etc etc.
who cares.
go take it to another dyno for one run, and see what you get.
you may be right mate,
thing is, I dont mean to say it like im cocky, but it feels like its got alot more then 215kw... considering my car was doing a smidge under 200kw with the standard turbo, compared to that, this thing has a ton more kahonies, but I couldnt explain the low kw results.
i cant remember on the stock one, 300-400nm?
and I guess Sam didnt put the torque figures on this sheet, but on a the dyno we did previously to this tune (about 3 months before) when there was less power downlow but overall pretty much same uptop, it had 640nm@130kph, now it feels like more again, but obveously cant tell until perhaps another dyno run.
and the only difference in these 3 months is a new metal cat and fixed a small exhaust leak.
so that would explain why it feels like it pulls much harder no?
Because its bush bearing, and comes on in the later RPM - kinda gives you a 'rush' effect.
Same thing as what my GT-SS/RB26 feels like vs my GT30/RB25
GT30/RB25 felt heaps more powerful, but thats because it came on around 4000-4500rpm and felt like a rocket (sounded like one too)
The GT-SS's are making decent boost from the mid 3000rpm and it doesnt 'feel' as fast... but its certainly no slouch and i wouldnt be surprised if its faster than my RB25 even though its making 20-30rwkw less
yep, definetly feel that rush, but there is still alot more low-mid range because of Sam.
I know you guys say not to aim for a certain kw amount, but I would have thought this setup would be at a minimium of around 240kw, not 215kw.
and raz, I know others have made alot more power, I have no idea why its at this low level, but its not as if i havent put money into the mods,so I cant think of what would be restricting it except for a little missfire?
Adam
But isn’t this is a High comp NA RB25 with a Turbo kit bolted on? Probably started to detonate with high boost. Need to install a Thick head gasket to lower compression before add in more timing and boost. The max power as I've seen out of TR43 on normal RB25det is 261rwkws at 20psi.
But isn't this is a High comp NA RB25 with a Turbo kit bolted on? Probably started to detonate with high boost. Need to install a Thick head gasket to lower compression before add in more timing and boost. The max power as I've seen out of TR43 on normal RB25det is 261rwkws at 20psi.
it is, and in principle your right, but as others have said, and I believe as well, that it should have alot more power at 15psi then 215kw, and it hasent been detonating, just a little missfire.
secondly, keymaker, I do wish it i was recording it in awkw, but no, it is in rwkw unfortunetly. :)
Look this is from a Normal RB25det's dyno sheet of hypergear's website tuned by Sam. Car made 230rwkws at 14psi and this is not bad power curve. Other wise you can try Trent at Status tinning. He might be able to get more power, as Sam prefer safe tune, so it can be possible that it’s not tuned at its limit with your misfire issue.
Edited by kwickr33
I too would prefer a safe tune if i didn't have lots of cash to build and engine.
Get the issues sorted first before worrying about the dyno chart.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
