Hi Daniel welcome to SAU
i spoke to you last year about the setting up of events
anyways Kudos to you and your team as i know its a group effort to get an even off the ground
Thanks for the kind words! It's hearing feedback like that that really makes organising these days worthwhile!
Does anyone here know Martin Donnon well? I was thinking it'd be great to try and get him to do a demo run in the R35.
  • Replies 305
Nah he can enter for sure!! Hell, there's a 500rwkw Supra from Mildren that is entering too!
That wouldn be the one that was at Boostworx DD (Black one) 470-480 from memory
C'mon Martin bring the 32 with the os giken 3litre.......Would make the RB vs JZ rather interisting.
Good work with organising the day too Daniel should be good.
Thanks mate. I'm just trying to make this day as big and as varied as possible so everyone's tastes are catered for.
ahh crap i totally forgot about this one lol
umm so do we just call graham west and make a payment and time of run that we want?
is that how it works?
Edited by Krishy
dang, i got cricket. would love to go head to head with u now krishy!
That would be nice Damo
all in the name of fun
Yeah i have, how many cars have you got confirmed to date Daniel.
yeah keen to know that
how did you end up paying for it RB25DETS2?
All you need to do is call Westy's and enter. What will happen once the field is full, i'll arrange the competitors into their classes (all of the Skyline, Supra, Soara etcs in the RB v JZ challenge will be together) and allocate a time.
Last time I checked we had 19 out of 40 spots filled, and we've got a month to go!
Rang up Graham Wests and paid the $40 with plastic over the phone. Received a receipt 2 days later in the mail.
Edited by RB25DETS2
so how many people on here have actually entered this particular event?
I paid my dyno day fees last friday
so keen on this dyno event.....should be a good day out...
go on pete chuck the land cruiser on the dyno lol.....
common damo put the 34 on the dyno mate
it will be good to get another nice figure
and remember last time your cat was restrciting it so much so the highflow now will make the difference :thumbsup:
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
