  • Replies 305
really?? hmmmmmmmm
na, i think the boss would kick my ass, if it was mine, i would.
i could always put wendys auto lancer on the rollers? no shit, i reckon that thing has about 13fwkw ! pos
Going to the next modern Reg' chad?
It's the day after the dyno day (15th)
Nope, I want to try and enter the time attack at the end of the month.
Hey Chad, yes if you request to be put on first thing that shouldn't be a problem, just note it on your entry form I think.
I'll have a chat to GW about it.
are you still trying to put the club members together against the Jz boys
Matty 31, should be plenty of spots left, call GW as they will be able to tell you.
Madaz, im not one of the organisers sorry, that would be best directed at Dan, BLU555.
The classes are still going ahead (RB vs JZ), but i don't think they will be back to back. so if DSTROY makes the most out of the RB's early morning well he'll still be the winner.
the days, although busy arn't heaps strict so if things can be juggled around to suit everyone as best as possible that's what happens :(
Edited by BlitzSSS
Chad,
If you need to get on early, I can organise that, no problems. As Paul said, there can be some suffling around of places too to accomodate entries.
Thanks for your supprt guys too. It's great that irrespective of the club, we can all get together and enjoy our cars. Oh yeah, expect some very heavy hitters from the GSR Evo club too!
Cheers
Daniel.
Chad,
Cheers
Daniel.
So is there anyway we can know before the day what times our runs are?
i know this starts at 8 and i will try to get there before then but just wondering if
there is someway of knowing when my run is thats all
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
