Pga-sa Interclub Dyno Day #3 - 14th March 2009!
car_fanatica
 Share
  • Replies 305
Thanks!
I'm in the process of organising a bit of a surprise for you skyline boys on the day :(
oooohh i cant wait for that suprise
free Garrett turbos for every entrant?
Damn that would be nice suprise wont it damo
free kisses from a certain someone who likes feathers and purple :D:O
So luke is going to be there
me and dave might pimp him out again
and try to cover the cost of the dyno day fees lol
Thanks!
I'm in the process of organising a bit of a surprise for you skyline boys on the day :sick:
Oh, just thinking, i hope it isn't a 900rwkw 2JZ supra or something to completely destroy our hopes of taking out RB v JZ
sorry to say i may have to pull out as i spun a bearing today :glare:
anyone with a AWD want to buy my slot
will prolly still pop down as its a great day out and go to love a snag with RB goodness
sorry to say i may have to pull out as i spun a bearing today :(
sounds like time for a rips engine, lift kit and some paddles....
I just wanted to say thanks for all the interest the SAU guys have shown in the event - you guys have been keen every year, and have out done yourselves again!
The amount of links from the forum to the www.dynoday.info site from SAU are more than double the next one, which is the PGA itself lol.. Great work!
sorry to say i may have to pull out as i spun a bearing today :)
if you want a lift there steve, i daresay any of us northies will be more than willing to let you ride shotgun.
So hurry up dave and organise something for the meetup for that day Dave
or do you want me to go ahead and work something out???
Should be a awesome day
now i cant wait
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
